August 22, 2025, 07:41:10 AM *
Author Topic: Brake Booster  (Read 3361 times)
Rod
« on: June 08, 2002, 09:43:39 PM »
Hi everyone. Has anyone got fitting instructions or thoughts on where you place a brake booster on a FE/FC. I have access to one and don't want to drill or cut any unnecessary holes. I would like to put it in the position where it was intended to go.
Thanks in anticipation.
Rod
graham_fuller
« Reply #1 on: June 08, 2002, 11:10:26 PM »
Hi Rod
I have my VH44 booster Fitted 585mm from the firewall to the back of the booster.It has 2 brackets one rear and one front. Grin Hope this helps.
Cheers,Graham Smiley
FE_UTE
« Reply #2 on: June 08, 2002, 11:46:00 PM »
Hi Rod
I have the original NASCO instructions for fitting part no 7425375.The illustration is for FB/EK.There are six pages of detailed instructions
Can scan and email if you can use
Gary
brads59
OLD OLDENS=STYLE
« Reply #3 on: July 05, 2002, 06:46:50 AM »
Hi, ive stashed mine up under the drivers side guard,
out of view and the lines fit between the fire wall and y frame.My ol girls not on the road yet but i cant see any problems with it.Good luck....... Brad
1959 Black Std sedan
FC-V8
Not enough hours in the day
« Reply #4 on: July 05, 2002, 08:45:26 PM »
Hi Rod
   I installed a VB commodore dual diaphragm booster to the firewall of my FC using a bracket i made up that has the booster about 1"inch from the firewall and uses the existing master cylinder holes(looks very neat & tidy)
I know some people install HK boosters but the stock HK bracket has the booster a long way from the firewall & having remote boosters is ok but why do that when you can mount it directly to the firewall in FE/FC.
hope this helps
Glenn
0401-065-201
