July 27, 2025, 06:21:04 AM *
Author Topic: Grey motor assembly  (Read 3105 times)
brandt
« on: September 29, 2005, 09:05:05 AM »
G,Day Im currently rebuilding a grey motor at my place of work. the job has been givin to me with out my knowlege of its disassembly. Im after any info on specs such as tollerences clearences tourques and conrod and piston assembly by this i mean which side of the block does the oil sprays or rod numbers go. i am persuming that the notch in the top of the piston goes to the front of the engine. any help or copys of relevent pages of a manual will be muchly appreciated. Thanks
« Reply #1 on: September 29, 2005, 09:56:42 AM »
There's a fair bit of useful info here and here, but a workshop manual is really what you need.  What part of the world are you in?
brandt
« Reply #2 on: September 29, 2005, 10:49:31 AM »
tell me about it but work will not purchase one for what is most likely to be a 1 of. im on the sunny coast in qld.
FC0058
Jim Altmann
« Reply #3 on: September 29, 2005, 06:35:27 PM »
Brandt
The QLD club has a few members up around the Sunny coast, if you have a look at our website you will find some contact details, or if your down Ipswich way I am sure one of use will be able to give you the info you require.
Cheers Jim
PS The Sunny coast has an old Holden club not sure what the contact details are though.
fc_1958
FC5959
« Reply #4 on: September 30, 2005, 09:38:02 AM »
Hey Brandt
Torque specs as per RET's links.
Notch on pistons to front of motor oil hole to camshaft.
The rest is straight forward.
Andrew..... AKA   FB 60 on the "other" forum.
brandt
« Reply #5 on: October 04, 2005, 11:15:09 AM »
thanks for your help
all is now done courtesy of our local library
having a manual
