September 09, 2025, 01:13:59 PM *
Author Topic: 2 speed wiper motor  (Read 5679 times)
mike06
« on: September 28, 2005, 10:42:20 AM »
Im currently rewiring my fc and im stuck at what to do about fitting a different wiper motor. If anyone has any sugestions on what to use it would be very helpfull.
fcdunedin
chris sayers
« Reply #1 on: September 28, 2005, 11:05:55 AM »
I'm sure you will probably get a reply from Ken McLean,I bought one from Ken and it works great excellent fitting instructions and also came with trouble shooting advice..
mike06
« Reply #2 on: September 30, 2005, 02:55:18 AM »
How much did it set u back.
« Reply #3 on: September 30, 2005, 06:44:11 AM »
Mike, cost of 2 speed wiper motor is $80 with trade in of EK single speed wiper motor.  You must have the 2 small arms on the back of the EK motor in order to make the conversion work.
mike06
« Reply #4 on: October 04, 2005, 06:27:01 AM »
Ken im intrested in getting one of these two speed motors but i dont have an ek motor to trade in. Also would u be able to give me a bit of information about the  conversion does it come in some sort of kit etc
thanks mike
« Reply #5 on: October 04, 2005, 08:12:48 AM »
Unable to supply at present because I dont have any EK donors either.
Comes as a bolt on package with switch, installation instructions and wiring instructions.
You find me a EK wiper motor and I will supply you a guaranteed working 2 speed motor that will bolt straight into an FE or FC.
TorqueFC
Modified?
« Reply #6 on: October 04, 2005, 08:15:38 AM »
hey mate
ive got quite a few ek electric wiper motors here, drop me a pm if your interested
« Reply #7 on: October 06, 2005, 11:45:21 AM »
Torque (and Mike06 if you're on the hunt for a conversion unit):
When I converted my single-speed EK motor to one of Ken's two-speed jobs, my EK wiper motor was no use to him as an exchange.  There are two types, AC Delco and Preslite.  Only the latter could be modified into a 2 speed unit.  This may have changed since.
The Preslite motor has a groove in the lower end of the casing like a piston ring.
« Reply #8 on: October 07, 2005, 06:25:33 AM »
Basically there are 3 components which are needed for my new conversion.
1. The base plate - Preslite is perfect, Delco has to be redrilled to fit.  Also need the rectangular rubber insulator.
2.  The primary drive arm - Once again Preslite is perfect, Delco has to be cut and welded to work.
3.  The secondary drive arm - Both Preslite and Delco have the same arm so both are good.
In short - I can make both work, but the Delco is a bit more trouble.
IMPORTANT - I need the 3 items listed above, a lot of EK wiper motors you will find do not have the 2 small drive arms on them - these are virtually useless without the drive arms.
I am willing to buy as many EK wiper motors as I can for stock, bearing in mind that I have to buy from the wreckers the donor 2 speed motor and a switch and spend an hour of my time putting it all together and still sell at $80!
mike06
« Reply #9 on: October 07, 2005, 01:55:27 PM »
If i buy an ek motor from torque350 how much is it going to cost me still or will u do it cheaper.
« Last Edit: October 07, 2005, 02:06:18 PM by mike06 » Logged
« Reply #10 on: October 08, 2005, 08:25:21 AM »
Mike  - I will covert for $70 if you supply Preslite motor, or $75 with Delco.
Regards  Ken
Page created in 0.036 seconds with 17 queries.
