August 28, 2025, 09:35:39 AM *
Author Topic: powder coating  (Read 1621 times)
knickers
« on: September 16, 2005, 09:56:29 AM »
Am thinking of getting some bits 'n' pieces powder coated to look like zinc plating & wondering if anyone has done this, if so what are the results like & what colour was used
« Reply #1 on: September 19, 2005, 11:54:55 PM »
Hi Nickers,
I have seen it done and reckon It looks pretty good, but if you are after the OEM look, I don't think it is very similar.
I'm going "cheap" and trying some silver paint from POR15 on all my normally zinced bits.
HTH
knickers
« Reply #2 on: September 20, 2005, 03:08:24 AM »
Was thinking about powder as an alternative because it's closer to the powder coater than the plater, but as yet I havn't seen any of the powder coated silvers in reality only computer samples
You say you're using  POR15 - is that because it's close to a zinc finish or because it works out cheaper or both.
« Reply #3 on: September 20, 2005, 03:17:56 AM »
Do you have any pics of the zinc finish that you are after?
The powder coater I use has a pin-up board with samples of every colour that they stock. I have seen this at other powder coaters too, maybe you should drop by your local coater for a squiz.
Page created in 0.024 seconds with 18 queries.
