July 19, 2025, 03:13:14 AM *
Pages: [1] 2   Go Down
Author Topic: Building the nest.. wired for sound.  (Read 11449 times)
« on: September 14, 2005, 04:18:37 AM »
Hello ppl,
Just thought i would post a pic of some work I have been doing lately.
I haven't really contributed anything useful forum wise so this may be interesting.
there was some talk about car stereo a little while back, which got me thinking into how to instal a relatively discreet system.
after much brain scratching on where to put the amps I found a spot (see pic).
Under the rear floor of course, I may need to vent the floor better but hey at least they are out of sight.  A simple tube frame keeps it bolted down, and also stops my spare from wandering and smashing the amps.  the MDF board to the right is for the electrics.  4AWG wire feeds a fused distribution block, which in turn feeds the amps via 8AWG wire (now fitted but not pictured).
dynamat was used to stop panel vibration and resonance.
Nice big RCA leads feed the amps from the head unit.
you can see the battery tray, top of stainless tank, and where the spare wheel fits (snugly).  A low profile, narrow 14inch tyre was best suited for this area.
Next up, will be making the lids (or floor) from 12mm MDF.
and the car is coming home to fix up some loose ends before the trimmer works his magic.
all for now.
nicko
« Reply #1 on: September 14, 2005, 07:57:54 AM »
very neat and effective set up you have bud.also looks like a nice space under frame for a tool box.
cheers Nicko
« Reply #2 on: November 01, 2005, 11:08:35 PM »
.. small project update.
the audio is close to completion with speakers about to be fitted.
audio cabling (lots of it) has been secured down to the floor and along the panels.
Car is being sent to trimmers next week, a nice headlining has been ordered and shall be fit up.
getting close now Smiley
« Reply #3 on: November 02, 2005, 12:06:54 PM »
Great to hear about your progress.
Can't wait to see the wagon.
« Reply #4 on: November 11, 2005, 12:29:39 AM »
more sound...
the guys at Tuffy Alexandria are top notch and know their stuff.  they looked after me well and have built a fab exahust.  they tol dme shoulkd I want to alter anything I can come back in and it will be done.
pics of the 2 1/4 dual system stainless with magnaflow mufflers.
fccool59
« Reply #5 on: November 11, 2005, 07:35:55 PM »
does it drive now, or is it pushed and towed? looks like your on the home run now.
« Reply #6 on: November 11, 2005, 09:33:27 PM »
It drives  Grin
still gets towed around for the time being.
currently being trimmed (as are the contents of the wallet)  :-/
bent8-58
The older it gets-the slower it was!
« Reply #7 on: November 17, 2005, 12:07:55 PM »
Nice goin Ed,
  Good to see progress! My FC had the REAL music system installed a few weeks back too. A good mate of mine works at  Carline muuflers. We did a twin 3" with a X pipe then twin 2 1/2" back to the rear  of the car. It was touch & go whether it would fit that size over the diff, not to mention brake lines,fuel pump,fuel filter & shockies all playing their part to be in the way.But he got it all in there with 2 spiral flow mufflers right at the back of the car. l had the same motor in my HG ute before the FC with a twin 2 1/4" but it wasnt big enough, although it had a nicer note( a bit more sedate)
The FC sounds totally different,probably too loud for me but we'll wait & see how it goes, its weird because at idle & up to 2000 rpm it has a raspy,tubular note & over 2000 it has a completely different note,you'd swear it's a different car. Anyway good luck with the trimming! Daz
I LOVE CATS.....BUT I CANT EAT A WHOLE ONE BY MYSELF.
« Reply #8 on: November 17, 2005, 10:15:36 PM »
Hey Daz,
your car sounds pretty wild!!
i know what you mean about shockies, fuel pumps, diff, tanks all getting in the way of the exhaust.
we decided to go under the diff for a better result.
some heat tape to protect the lift pump.  I thought this was going to cause a big headache but no problems in the end.
the car is getting inspected on Friday, fingers crossed...
« Reply #9 on: November 17, 2005, 11:09:47 PM »
Best of luck for the inspection, Ed.  Not long to go now, eh?
« Reply #10 on: November 18, 2005, 12:04:16 AM »
Hi RET,
thanks, initially i was estimating time of completion in years,
then as i got got closer it was months
I reckon now I am down to weeks.
Maybe this Christmas it will be done Smiley
« Reply #11 on: November 19, 2005, 05:54:09 AM »
the car was just inspected by the engineer.
the inspection went very well with only a few items / photos required for the certificate.
1) external rear view mirror.
2) fan shroud fitted.
3) window stamps etc on the windows which are not fitted at present.
the brake test will need to be reperformed as the car was not travelling fast enough to get the required reading.
With light pedal effort it still managed 0.8G.
the car then decided it was going to have a no start.. hmpph, the dizzy had moved and static timing was slightly out.
in this state, it managed to pass the noise test 94 (or 96??) dB at 3000 rpm. (and wouldnt pass at 2850!)
all in all.. Very happy!
The certifying engineer Peter Gillard is worth a call if you need an engineer.
« Last Edit: November 19, 2005, 05:55:08 AM by EH » Logged
GM
« Reply #12 on: November 19, 2005, 09:09:19 PM »
Hi Ed, gotta be happy with that. One of those those little droop mirrors that clamp to the top of the door maybe? Gotta see it when you finish.
                            Cheers Glenn
Phantom
« Reply #13 on: November 19, 2005, 11:26:21 PM »
Like this one? , got it from rare spares for $56, someone keeps selling em on ebay for well over that ,
                               Cheers Rusty
Bogans rule
Phantom
« Reply #14 on: November 19, 2005, 11:27:31 PM »
another one , i know its only a mirror but i like taking pics of my car ,
                     Cheers Rusty
Bogans rule
TorqueFC
Modified?
« Reply #15 on: November 20, 2005, 12:00:07 AM »
hehe rusty who doesnt. below is a pic of the one on our 350 sedan, the mirror is quite dirty (the hole car is, thats what ya get with a daily driver!)
i tihnk they are about $60 each new from rares
Just40
« Reply #16 on: November 20, 2005, 03:08:09 AM »
i got a set of 2 like rusty,s in a box brand new at a swap meet 3 months ago for $60.00,i was going to get them from rare spares.
GM
« Reply #17 on: November 20, 2005, 06:24:18 AM »
Yeah, like that one Bogan. But mounted top of the door. Bit of a hot rod look about it.
       Cheers, Glenn
« Reply #18 on: November 20, 2005, 10:59:30 AM »
Hey Ed,
Also got the same on the van... Came from Harrisons for $50 a pop.
So I'll see you soon in Cairns  Tongue
« Reply #19 on: November 24, 2005, 09:31:32 PM »
Hey guys,
Thanks for the replies, sorry about my delayed response, was in Perth and computerless.
yeah will steal back my mirror from the EH.. heh heh, we took it off the FE years ago.
short hop to Cairns hey Jas, the maps are out already.
Pages: [1] 2   Go Up
Page created in 0.262 seconds with 20 queries.
