May 18, 2025, 05:22:43 PM *
Author Topic: VN V6 conversion (ECU Diagram)  (Read 9165 times)
kiwipdnz
« on: September 09, 2005, 10:03:10 AM »
Hi this question probably has been asked a thousand times.But is there a easy to use basic plain english wiring diagram to make my motor run.I have put a v6 in my ute and would like to get wiring sorted.I could take it to a sparky,but what sort of challenge would that be?.I hope someone can help.Cheers Huh
« Reply #1 on: September 09, 2005, 11:03:00 AM »
Castle Auto Electrics have conversion kits for this -
http://www.castleauto.com.au
« Reply #2 on: September 10, 2005, 04:25:55 AM »
Hello,
ECU wiring, can be nutted out pretty easy.
Get your hands on the GMH book..
hmm I think its Vol 4 Engine Management, I used the VN 5.0L version, however the ECU and sensor hook up is identical for any motor using the Delco 808 ECU.
this allows you to do anything you desire :-)
like ECU controlled engine fans etc.
not sure of the castle auto kits.
Google Kalmaker and go to the forum for more info.  Injection Connection in Perth make a power head haness if you find the wiring all too daunting.
if you read the book and understand the basic principles of operation you should be OK.
kiwipdnz
« Reply #3 on: September 10, 2005, 08:46:46 AM »
Thanks guys,I will look into it.At least it's a start.I have a VN work shop manual.But i have never seen diagrams so bad.Cheers
« Reply #4 on: September 12, 2005, 09:16:26 PM »
I use the Gregorys VN manual and it is reasonably OK, however there are a few differences notable in the wiring.
I modified a V8 engine harness, then used a V6 relay panel and modifed that wiring to fit up to an aftermarket fuse panel... not too hard just very time consuming.
the GMH book is the one that is most helpful, I see them on evil-bay all the time when i search under "Holden V8".
Page created in 0.048 seconds with 20 queries.
