May 18, 2025, 01:41:11 PM *
Author Topic: Coil Springs  (Read 2190 times)
sgo
« on: August 31, 2005, 08:41:31 AM »
Are there any later model holden coils that will fit into a HR front-end??
FC-225
« Reply #1 on: August 31, 2005, 10:32:58 AM »
Yep, I have SLR 5000 Torana springs in mine.
AL
sgo
« Reply #2 on: September 02, 2005, 09:00:36 AM »
Also found out today that HT also go in, so i guess there must be a few types compatible.
« Reply #3 on: September 02, 2005, 09:10:57 AM »
The questions are now,
- are these springs all the same height? and
- do they compress the same as HR springs?
FC-225
« Reply #4 on: September 02, 2005, 09:20:44 AM »
No they are'nt, the SLR 5000 are obviously a V8 spring which has a longer free length ,plus thicker wire diameter,which results in a much higher spring rate,than a standard 6 cyl.
Usually if you have a 6 cyl, you would stick to a 6 cyl type of spring rate,just altering the lengths to get a required ride height..
AL
sgo
« Reply #5 on: September 02, 2005, 11:10:32 AM »
I should add that although they are for a ht, the springs I ended up using were a Pedders type that were 265mm free length as opposed to about 305mm for stock, so obviously a lowered set, and quite a bit firmer than stock as well.
It was the third set I fitted to get things right for a not stock front-end etc.  Roll Eyes
Page created in 0.029 seconds with 20 queries.
