September 08, 2025, 03:27:49 AM *
Author Topic: Harmonic puller  (Read 5709 times)
fc_1958
FC5959
« on: August 25, 2005, 09:03:59 PM »
I want to remove the harmonic pulley on a grey - preferably without damaging it.
The manual shows a special puller which is basically hollow tube with an external thread which screws into the center of the harmo - a bolt screws into the center of the puller which with tightening will push the harmo off the shaft.
I am having no end of trouble locating one of these tools. A visit to rare spares resulted in failure, the rep wanted to sell me a 3 bolt type used for red motors. After some talk he showed me their catalog and yes, the replacement now available is of the red motor variety.
Talking to a backyard mechanic I was informed that a 3 claw puller will do the trick - yes sure it will get it off but will it damage the harmo Huh
As I have 2 FC's - 1 on the road and one under restoration plus 3 spare greys (one will be rebuilt as a spare - just in case when FC2 is on the road).
I would like to acquire the correct tool or at least not damage the harmos whilst removing them .
So any advice as to where to score the correct tool or is the claw puller method acceptable??
Andrew
Andrew..... AKA   FB 60 on the "other" forum.
TorqueFC
Modified?
« Reply #1 on: August 26, 2005, 03:31:54 AM »
a 3 pronged pulled will be fine only if the motor is not in the car, if it is the car it wil be very dificult. also you will need to undo the 2 front engine mount bolts and lift the motor up
colt
« Reply #2 on: August 26, 2005, 04:46:23 AM »
Where are you? Most of the grey motor guys would have 1 of these. You may be able to borrow one.
Colin
colt
fc_1958
FC5959
« Reply #3 on: August 26, 2005, 07:39:49 AM »
Thanks for the info TorqueFC - the motor is currently on a stand it is out of FC2 which is my restoration project so it should not be a problem.
Colt, I am located 40 km from Wagga ( that's 25 miles in FC talk Grin ).I do not like to borrow tools, if they break you end up buying a replacement so I believe it is better to buy myself the new / secondhand  tool then be left with an old broken tool.
I intend to rebuild the motor myself, minus the machining so spending a few $$ on tools is well and truly offset in labour savings - besides I need an excuse to get myself to the shed on weekends   Roll Eyes
greyside
life is good,old holdens also
« Reply #4 on: August 26, 2005, 07:42:39 AM »
its best done motor out
TorqueFC
Modified?
« Reply #5 on: August 26, 2005, 07:44:51 AM »
you can not buy the original harmonic balancer pullers new. although they do come up from time to time on ebay, i think the last one went for about $30 or so. the 3 pronged type which will be fine for you is available from super cheap auto, cant remember the price but it was pretty cheap
fc_1958
FC5959
« Reply #6 on: August 26, 2005, 07:54:09 AM »
Excellent - I already have a 3 prong reversible and the 3 bolt variety - will keep an eye on the postings here and ebay
« Reply #7 on: August 26, 2005, 10:16:40 AM »
I wouldn't use a 3 prong puller - it will most likely damage the harmonic balancer.  I have one available for the price mentioned - $30.
Regards   Ken
fc_1958
FC5959
« Reply #8 on: August 26, 2005, 11:20:05 AM »
And I would like to buy it for the price mentioned Cheesy
Please send me your bank details and postage cost to Coolamon NSW 2701 so that I can transfer the $$
Andrew
knickers
« Reply #9 on: August 28, 2005, 10:42:09 PM »
Ken these are the ones you see on ebay & in shops  - are these pullers you are referring to if not are these suitable
suitable
Cheers Nickers
« Reply #10 on: August 29, 2005, 09:57:34 AM »
No not suitable at all - they wont work since there are no holes to screw the bolts into.  The 3 jaw pullers which can Huh be used are the ones with three hinged legs which grip under the edge of the belt flange.  They tend to bend the flange where the belt runs and separate the 2 halves of the balancer.
fc_1958
FC5959
« Reply #11 on: August 29, 2005, 10:18:18 AM »
Hey Nickers
Works well for steering wheels and red motors also suitable for the present day replacement grey harmos sold by rare spares.
Andrew
