May 18, 2025, 11:08:00 AM *
Author Topic: What are these finned brakes off?  (Read 5184 times)
SRVLIVES
« on: August 21, 2005, 08:06:09 AM »
On the rear of my FC, I'm sure these are the same as were on the back of a modified EH I had about ten years ago.
TorqueFC
Modified?
« Reply #1 on: August 21, 2005, 08:23:09 AM »
they look like standard fc to me
SRVLIVES
« Reply #2 on: August 21, 2005, 08:30:12 AM »
photos of rear end if that helps.
TorqueFC
Modified?
« Reply #3 on: August 21, 2005, 08:33:35 AM »
what motor is in the car?grey motor?
SRVLIVES
« Reply #4 on: August 21, 2005, 08:39:25 AM »
Red 202, HR front end
TorqueFC
Modified?
« Reply #5 on: August 21, 2005, 08:40:59 AM »
well then i dare say that id be wrong. can you pleaze post a picture of the diff yoke, and a picture of one of the backing plates
« Last Edit: August 21, 2005, 08:41:46 AM by torquefc » Logged
« Reply #6 on: August 21, 2005, 08:45:03 AM »
Hi SRVLIVES,
It's a  FE-FC Brake drum and diff housing Wink
From memory when i looked at it a couple of years ago it had a later model diff centre.
Regards ACE  Cool
SRVLIVES
« Reply #7 on: August 21, 2005, 08:45:48 AM »
None handy, and the car's not here.
I think those U bolts may need a trim though....  Wink
TorqueFC
Modified?
« Reply #8 on: August 21, 2005, 08:50:02 AM »
well then id say that ACE is correct seings he has seen the car
SRVLIVES
« Reply #9 on: August 21, 2005, 08:54:31 AM »
Which leads me to my next problem, my HK/T/G wheels mounting face is obviously different to the drums which is why my rear wheel studs only protrude just over halfway into the nuts!
I feel like just throwing a set of 13's back on it.... Sad
Online Online
« Reply #10 on: August 21, 2005, 10:09:12 AM »
Don't cut the U-bolts!!!! Add lowering blocks  Grin
Are you running drop spindles on the front end? If so you make strike more trouble. I bolted everything up today and the bloody wheel wouldn't spin, backed off the nuts and found the rim was scraping in a couple of places on the lower ball joint. Goes to show how round the wheel is eh? It only scrapes in a couple of spots and not the entire circumference. Might do a bit of angle grinder work tomorrow  Shocked
How are you going to dress up you wheels? I tried one of those dariol moulds (67mm) I mentioned in another post and they worked a treat. A good set of chrome nuts and they will look the business.
SRVLIVES
« Reply #11 on: August 21, 2005, 10:47:11 AM »
No drop spindles, just lowered springs.
I may have another alternative for wheels, just seeing what the freight cost would be.
Online Online
« Reply #12 on: August 21, 2005, 11:18:17 PM »
I am off to buy a bottle of peroxide tomorrow.
Forgot that I hadn't tightned the ball-joints, intending for the place doing the align to go over the whole front-end and check/tighten everything.
Once that was nipped up, no hassles!
Those wheel studs look a little short, but is the rim mounting properly on the hub? If the wheel is mounting correctly, I'd be looking for some longer wheel studs.
« Last Edit: August 21, 2005, 11:23:12 PM by stinky » Logged
SRVLIVES
« Reply #13 on: August 22, 2005, 02:51:46 AM »
The wheel is hard up against the drum, but it's mounting face is completely different.
Mmmm, what to do.....
