August 09, 2025, 08:01:56 PM *
Author Topic: Removing Interior Door Handles  (Read 1905 times)
REDMR2RED
FC Ute's d'best
« on: August 17, 2005, 10:53:52 PM »
Can someone provide the dimensions of the tool to remove the interior door handles.
I'm sure I've seen it on the Forum, but can't find it using the search option.
Thanks Kevin
1959 FC Holden Ute
« Reply #1 on: August 17, 2005, 11:25:13 PM »
I'm not sure OTTOMH, but it's a standard size.  If you go to Supercheap or Auto-One etc and ask for a interior handle and trim removing tool, you'll get one that does the trick.
Jason
« Reply #2 on: August 17, 2005, 11:26:43 PM »
Kevin
I got this from Super Cheap:
Check this post.
http://www.fefcholden.org.au/cgi-bin/yabb/YaBB.cgi?board=howto;action=display;num=1075429021;start=0
Jason
REDMR2RED
FC Ute's d'best
« Reply #3 on: August 18, 2005, 07:54:03 AM »
Thanks for the advice Ret and Jason.
I got to work this afternoon and made one.  Took less time than driving to Supercheap.
Works perfect, window winder off in 2 seconds, door handle off in 5 minutes after I figured out that someone had put the door handle spring on the wrong way.
One scratch plate fitted, one to go.
Kevin
1959 FC Holden Ute
