July 27, 2025, 10:24:23 PM *
Author Topic: Engine losing power under load  (Read 2127 times)
graham_fuller
« on: July 01, 2005, 08:49:34 PM »
My new engine has developed a major loss of power which I think is electrical.Just wondered what everyone else thought. I was driving it last night (yes in the pouring rain) when it developed a major loss of power at low speed. This continued until I finally stalled the car once I restarted it it was fine.
So I am a little confused.
Any ideas?
smithy
yeah its purple !
« Reply #1 on: July 01, 2005, 10:55:15 PM »
hi graham, have you had a look at your coil?
i had a similar problem with an old EH after spending money getting carb rebuilt, tuning, etc, turned out to be a faulty coil.
dean
graham_fuller
« Reply #2 on: July 01, 2005, 11:05:15 PM »
Hi Dean,
Is there a method of checking the coil and can it be an intermitant thing?
« Reply #3 on: July 01, 2005, 11:08:39 PM »
Graham,
If it happened in the wet it is more than likely a tracking problem whereby the secondary ignition circuit (coil/cap/leads/plugs) was arcing through carbon or moisture to ground. This is commonly either a crack in the dizzy cap, or in the coil tower. It could be lots of things, but look here first.
Good Luck,
FC58q
I love My FC's all 3
« Reply #4 on: July 02, 2005, 04:33:46 AM »
Hi Graham
you can check the tracking in the dark makes it easyer, I had a seized advance and retard weights in the dizzy on my p/van hope this helps
Ray Smiley
