September 09, 2025, 01:04:47 PM *
Author Topic: Pushrods?  (Read 4491 times)
deano
« on: June 15, 2005, 07:51:09 AM »
Hi Guys,
Thanks for the help with the rocker removal removed the pushrods from my 138grey and found that 4 are slightly bent, can I still source new ones or can I staighten them myself?
« Last Edit: June 15, 2005, 08:44:53 AM by deano » Logged
cer444
138 "Big Block" Grey
« Reply #1 on: June 15, 2005, 08:24:26 AM »
If you have a Grey engine second hand pushrods will be the go.
Be careful with Red motors they have 3 different length pushrods so get the right length.
Pushrods are not worth the effort for straightening!!
« Reply #2 on: June 15, 2005, 08:32:09 AM »
.....and grey motors have 2 different length pushrods Wink
ACE  Cool
cer444
« Reply #3 on: June 15, 2005, 09:06:35 AM »
  "You learn something new everyday"
I didn't know Grey's had 2 different length pushrods.
Thanks ACE.
            Regards Aaron
PS..... Why did they have 2 different lengths? I know Red's had different lengths for different block heights/Rocker gear (I think)?
gp
« Reply #4 on: June 15, 2005, 07:15:21 PM »
Don't know WHY they changed them, but the lifters are also 2 different depths. Huh
julius
« Reply #5 on: June 15, 2005, 10:17:11 PM »
The reason why is because they have 2 different depth cavitys for the pushrods to go into the lifters in the grey.
Julius
graham_fuller
« Reply #6 on: June 15, 2005, 11:13:13 PM »
Pushrods are easily straightend as my previous motor bent 2 and I successfully straightend them in a vice with soft jaws and a hammer. Worked fine for 6 years until the engine was rebuilt.
FCwagon
« Reply #7 on: June 16, 2005, 07:50:28 PM »
Grey's have 2 different lengths because the early engines did not have a drain hole in the cam follower and oil that sat in them sludged up easily and also couldn't drain out at oil change intervals. All up they hold about 1/2 pint.
Straightening pushrods is a temporary fix unless they are done perfectly. Because they're expected to rotate in operation.
cheers,
Leigh
Red & white is alright
Tumbles
ute's kick ass
« Reply #8 on: June 17, 2005, 09:25:15 AM »
I believe there are a couple of differn't width rods as well, are they relative to the length?
Tumbles
SUPREME RULER AND DICTATOR-FOR-LIFE
It all starts with a second term in power!!
Page created in 0.032 seconds with 17 queries.
