August 29, 2025, 01:20:12 AM *
Author Topic: DIFF IDENTIFICATION  (Read 2456 times)
TorqueFC
Modified?
« on: June 15, 2005, 06:44:31 AM »
here is a pic of the diff that we just pulled out of a hr wagon
doesnt quite seem like a hr diff
when stripping the car we noticed that the brakes were mounted in another position and also after removal, we measured it against a standard fc diff and it turned out shorter. it was my understanding that hr diffs were shorter so this leads me to expect that it is a torana diff
any help would be great
Torque
TorqueFC
Modified?
« Reply #1 on: June 15, 2005, 06:45:23 AM »
also anyone know how how to tell what ratio it is???
FEHOLDEN
« Reply #2 on: June 15, 2005, 10:19:12 AM »
hey torque
the two "long" bolts at the bottom tell me that is most likely a torana diff. i am running a 2.78 in my HT which came out of a torana rear end which looks identical to yours.
you will find the diff ratio stamped into the flange just behind the yolk.
hope this helps
denis
gp
« Reply #3 on: June 15, 2005, 07:21:23 PM »
Hey Darcy,
Also if you're going to pull the diff centre out of the housing, the ratio is written on the crown wheel.
Dr_Terry
« Reply #4 on: June 16, 2005, 06:17:21 AM »
Hi Guys.
The diff centre with the 2 long bolts is a 3.08 or a 2.78.
These are seen in anything HK onwards, but more commonly in Toranas.
AFAIK an HR diff is the same width as an FC diff, so the shorter one is probably a Torana LC/LJ/LH/LX converted to leaf spring mounts.
If you post me the exact length (drum face to drum face) I can identify it for you.
Dr Terry.
Page created in 0.027 seconds with 17 queries.
