August 28, 2025, 09:54:16 AM *
Author Topic: Ryco No. 463 Oil Filter  (Read 3477 times)
Rabbitoh
FE - 'King of Cars'
« on: June 06, 2005, 09:48:42 PM »
I have a remote oil filter for our grey motor, which is missing a vital fitting. Namely the 'R59-1/4 Elbow' which attaches the oil inlet pipe to the top of the filter body. Does anyone know if these are still available?
Also I have the original instruction sheet for fitting the filter, but can't work out how the Flexible hose ('L11D4') which has a cylindrical metal rod at one end, is attached. Does the metal rod end go into the motor or the filter? and how is this end secured? the No. 32 Dole nut & No. 12 connector fitting don't seem to hold it at all. Huh
Any help much appreciated.
Regards,
R.
Bunnies' 22nd in 2026?
« Reply #1 on: June 07, 2005, 08:14:34 AM »
The elbow should be the same as the elbow on the inlet manifold which provides vaccuum to the pump.  I have these available.
The swivel end of the hose goes into the fitting on the oil filter in both cases
The tapered end goes into the adaptor where the oil pressure switch goes in and the other goes into the engine block as the return port.
Rabbitoh
FE - 'King of Cars'
« Reply #2 on: June 08, 2005, 12:13:51 AM »
Thanks Ken.
Does this mean that there are 2 flexible hoses used in the hook up? (I wondered why there was a 2nd one in the kit). I have a double flared bundy steel tube inlet line which is shown in the instructions sheet as coming off the tee fitting where the oil presure switch goes in and attaching to the oil fiter inlet opening? The flexible (braided) hose is shown going from the bottom (outlet) of the filter and into the block. As to how the metal tube end of this hose is physically held in place, I'm still in the dark. What stops it sliding off under oil pressure?
I will need to buy that elbow from you. Just let me know the total cost (incl. postage).
R.
knickers
« Reply #3 on: June 08, 2005, 01:34:40 AM »
Rabbitoh
Check out article by custom fc in Other Images - Accessory of the week (11) Oil Filter - May 23rd, 2005,  & that my give you a better idea - it did for me
Cheers Nickers
« Reply #4 on: June 10, 2005, 09:05:24 AM »
Yes some oil filters had steel pipes instead of flex tubes.
Send me a $5 money order and I will return by post
Regards  Ken
Rabbitoh
FE - 'King of Cars'
« Reply #5 on: August 03, 2005, 07:30:17 AM »
Thanks to Ken I have the elbow fitting I needed.
I still have a problem with the metal tube end of the braided hose and how I fit it into the threaded crankcase aperture. (see picture-hopefully)
« Reply #6 on: October 27, 2005, 08:23:51 AM »
Chris, it has now just dawned on me what is wrong with your hose.  It is an incomplete item - what is missing is the fitting itself and then a flare on the end of the pipe.
Rabbitoh
FE - 'King of Cars'
« Reply #7 on: October 28, 2005, 07:40:39 AM »
Thanks Ken,
Does anyone have a picture of the fitting so that I know what I'm looking for?
« Reply #8 on: October 28, 2005, 09:53:08 AM »
Chris, whem you come round on Sunday I'll show you how it should look
