August 25, 2025, 08:23:40 PM *
Author Topic: Engineer's report  (Read 3125 times)
Liam Moloney
« on: April 30, 2002, 08:11:36 PM »
I was wondering if i needed an engineer's report for my Fe sedan which has a 173 red and 4 speed.
it has front disc, a brake boster, thermo fan and extractors i was told these may make a difference weather or not i need a report.
any help would be good thanx
Liam
slim
« Reply #1 on: April 30, 2002, 10:51:47 PM »
yes mate you will need an engineers report with a red motor in an fe ,no way round it . if their was id have found it ,,,,,, sorry
Im located at Liverpool, NSW
« Reply #2 on: April 30, 2002, 11:05:43 PM »
This will differ state by state. I am in NSW and have a 149 in my FC with the standard front end. I was told that if you can prove the car has been previously registered in your state with the engine and other mods you are OK.
I only needed to pay $20.00 to the NSW RTA to do a Microfiche search to find the last registration, which was over 10 years earlier. I was then given a blue slip with no problems.
Above is what happened for me but best idea is to ask your local rego authorities, they are really the only ones that will come close to giving you the right answer.
Good Luck.
Online Online
« Reply #3 on: April 30, 2002, 11:39:32 PM »
Liam,
Which state are you in?  It may make a difference.
If you're in NSW, you will need an engineers' report.  The details of what the RTA allow can be found here: http://www.rta.nsw.gov.au/registration/vsi06.pdf
Basically, 173 is more than 15% capacity increase over the grey, so that means an eng. report.
Hope that helps,
demon
« Reply #4 on: May 01, 2002, 01:39:48 AM »
   What if the car is all ready registered with a red motor cheers demon
Online Online
« Reply #5 on: May 01, 2002, 04:05:26 AM »
demon,
It comes back to what CraigA wrote - if you can show the car was previously registered with the mods, you should be OK.  If the car is currently registered with a red, then the answer would be the same, surely Huh
However, getting back to Liam's original question.  The first two items you mention are required under the NSW regs, but not the other two.  Additionally, you will need a heater/demister, electric wipers (2 speed or single speed at 45 sweep/min or faster) and seat belts front and rear.
Hope that helps,
Page created in 0.02 seconds with 17 queries.
