June 19, 2025, 04:06:17 AM *
Pages: [1] 2   Go Down
Author Topic: HR Rear End?  (Read 12032 times)
tim59fc
« on: May 18, 2005, 12:22:29 PM »
Here's my problem
I have a noisy wheel bearing on the left rear and a damaged oil seal, which is leaking diff oil into my drum brakes which are squeeling badly.
I have an HR front end with disc brakes, but how do I identify the rear end, and as such the appropriate new parts (bearing, oil seal and brake pads) without taking the whole axle off Huh
I'm a "Newbie" to this and the car (59 FC) is a daily driver so I don't want it off the road for too long.
Tim
Sarge
« Reply #1 on: May 18, 2005, 07:17:58 PM »
Tim
    Jack your car up put some stands under the diff for safety. Check if the the tailsharft is bolted to the diff yoke or if it has "U" bolts. If your car is useing "U" bolts the diff has been changed if it's still a bolt up uni-joint then the diff is original.
Hope this helps a little.
Sarge
        0421 165 351
tim59fc
« Reply #2 on: May 18, 2005, 08:58:10 PM »
Thanks Sarge
I'll give it a shot
If it ain't original it probably matches the front end
Tim
craiga
« Reply #3 on: May 19, 2005, 01:17:13 AM »
This will confirm that the diff centre is original or not, but not the diff housing, and therefore the brake and rear bearing seals may be stock FE/FC.
There has to be a difference in the backing plate design, can anyone help?
Craig.
fcfromscratch
FC - Fantastic Cars
« Reply #4 on: May 19, 2005, 02:22:02 AM »
Hi Tim,
I have a HR diff housing in my FC so I'll post some photos of the differences that will show whether you have an original housing or HR housing.
Basically, the HR housing has a "saddle" mount welded to the axle tubes for rear spring mounting as opposed to the U bolt/saddle/shock abs mounting plate set up on original axle housings.
Also, as Craig says, there are backing plate differences....and, if you're running boosted discs on the front and original drums on the back, there should be some pressure compensation device for the rear slave cylinders that should be obvious in the line to the rear otherwise the boosted line pressure will be too high for your 1" rear slave cyl's  (HR disc rear drum slaves are 9/16")....
I'll post some pics tonight....
cheers.....Brad
« Reply #5 on: May 19, 2005, 09:09:28 AM »
FC has 2 slotted holes in backing plate at top for adjustment, 1 each side of the wheel cylinder. HR has 1 adjuster at bottom in centre of backing plate.
« Last Edit: May 19, 2005, 09:11:48 AM by custom_fc » Logged
fcfromscratch
FC - Fantastic Cars
« Reply #6 on: May 19, 2005, 10:59:05 AM »
Hi Tim,
here's those pics I said I'd get you...
1.  rear axle saddle arrangement...
fcfromscratch
FC - Fantastic Cars
« Reply #7 on: May 19, 2005, 10:59:51 AM »
2.  same thing from the side...
tim59fc
« Reply #8 on: May 19, 2005, 11:47:21 AM »
Thanks Sarge, Craig, Alex & Brad Grin
From the above info I guess that I have an FC rear end though I'm still a little confused with the U-bolts means changed comment from Sarge vs the U-bolts means stock from Brad Huh
But Alex those two slotted holes are a give away Grin
PS Brad - I take it that means you have the power back on down your way.
Cheers Tim
fcfromscratch
FC - Fantastic Cars
« Reply #9 on: May 19, 2005, 01:13:07 PM »
Hi Tim,
yep, power's on, in fact we never lost it...
even better than that, broadband is a-happening...yay!!
Sarge is talking about "U" bolts on the diff yoke...the connection between the diff and the tailshaft..."U" bolts means later model diff......I was talking about the BIG "U" bolts that hold the axle tube to the shockie mounting plates....the old axles use "U" bolts whereas the HR axle uses the saddle plates as pictured on mine...
I'd be interested to know how the rear slave cyl's are set up...whether they've been reduced in bore or whether you have a pressure proportioning valve in the rear supply line from the booster.....or neither!!
do the rear brakes lock up under harsh braking...or are the shoes too oil soaked to know what "normal" is?
cheers....Brad
tim59fc
« Reply #10 on: May 19, 2005, 09:25:29 PM »
Gotta love broadband Grin
Here's a pic of my diff (with u-bolts also)
But I am now assuming that the bearing and oil seal I need to replace will be standard FC due to the backing plate.
I will do some investigation on the rear supply line and let you know.
Maaaate - I treat her too gentle to lock up the rear end - what are you inferring?
peterwmh
« Reply #11 on: May 26, 2005, 10:02:16 PM »
That centre looks like a 2.78 or 3.08 banjo centre from a Torana.  I fitted one to a HD last year and it had that longer bolt on the passenger side next to the drainhole bolt, earlier diffs had a thread and nut in this location.
Peter
Never late with a 308!!!!
NO NAME
« Reply #12 on: May 27, 2005, 07:24:51 AM »
I have always thought the long bolt was a high ratio and short was low, I always left in a long bolt and spaced it with wheel nuts when I had a low diff in.
This way whenever I got stuck on the side of the road with a blown diff I could fit either.
Phantom
« Reply #13 on: May 27, 2005, 09:04:05 AM »
G'day all,
                  This is a pic of my diff/tailshaft was told it is out of a LJ torona , any ideas?
                                            Cheers Rusty
Bogans rule
Effie C
Still Lost & Confused
« Reply #14 on: May 27, 2005, 10:04:13 AM »
Looks the same as the centre in my FC it came out of a HQ
tim59fc
« Reply #15 on: May 27, 2005, 10:49:43 AM »
Yo Brad.
Have done some grovelling under the car and think I have identified a pressure compensating device in the rear supply line. Unfortunately the camera died on me before I could get a shot. Will try and post something tomorrow.
I am not surprised that the diff has been changed as the car is running a 202 from a VK commodore (not efi) and has a trimatic from an HQ (so I was told)
Tim
SCUMMY
« Reply #16 on: May 27, 2005, 11:23:20 AM »
dont the longer bolts on the diff drain bolt and the 1 next 2 it mean its a lsd??? im shore it is had 1 in 1 of my old holdens till it whent bang!!
i keep it for a long time thinking to fix it 1 day? never did think it got ditched?
Sold The Vk
Sold The HT Prem
Got A Simplicity Ride On Tractor Now
LOL
stevefcvan
« Reply #17 on: May 28, 2005, 06:34:25 AM »
the long bolts do not mean its a lsd ,   the diffs with longer bolts from factory are 2.78 or 3.08  please inform me if i am wrong
« Last Edit: May 28, 2005, 06:39:03 AM by stevefcute » Logged
FEHOLDEN
« Reply #18 on: May 28, 2005, 10:32:08 AM »
gidday all
im running a 2.78 in the HT . it came out of a torana rear end and has the long bolts and it isnt lsd
denis
tim59fc
« Reply #19 on: May 28, 2005, 10:15:17 PM »
Here we go.
I don't believe that my diff is lsd.
Strange place to put a pressure compensating device - if thats what it is (under the drivers door?)
Difficult picture to take especially with some ugly mug staring at you (or is that me)
Pages: [1] 2   Go Up
