June 17, 2025, 01:54:36 AM *
Author Topic: installing distributer/vacuum advance?  (Read 1556 times)
Dave_EH
Keep on Holden' on
« on: May 06, 2005, 10:10:56 AM »
Hi,
I hope to install a twin point distributer on the weekend to replace my single point job.
I will be pulling the dizzy off my "unfished" donor motor I bought, which has not been started.  As far as I know the points have already been set.
I understand that you just need to have the no.1 cylinder at TDC for correct installation?
The new dizzy does not have vacuum advance - will this cause too many problems?
Should I block off the vacuum advance inlet on the carburettor or leave it open?
« Reply #1 on: May 06, 2005, 10:42:41 AM »
Hi Dave,
You need to have the No1 cylinder on TDC on the compression stroke. Wink
The vacuum advance is mainly a economy device on standard motors and you should block off the the vacuum port at the carby.
My opinion of twin point dizzys= double trouble.
My choice would be a electronic dizzy from a VC-VH and some VK 6 Commodores or a WB 6.
Regards ACE  Cool
Dave_EH
Keep on Holden' on
« Reply #2 on: May 06, 2005, 11:00:31 AM »
Thank you Ace,
you're a champ Grin  I will source an electronic dizzy, although since I had this new twin point sitting around and paid next to nothing for it I thought I may as well give it a run in the interim.
Page created in 0.028 seconds with 18 queries.
