July 19, 2025, 07:51:23 PM *
Author Topic: fitting door striker plates  (Read 1551 times)
FC-V8
Not enough hours in the day
« on: May 05, 2005, 12:52:47 AM »
Has anyone got any tips for fitting put the striker plates & those spacer type plates that go under the striker plates so I don't scratch put the paint while trying to align them with the door locking mechanism.
Glenn
0401-065-201
smithy
yeah its purple !
« Reply #1 on: May 05, 2005, 02:15:19 AM »
hi glenn, i ended up using some wide say 2 inch masking tape the veryu carefully moving the latch around so it wouldnt catch the tape, then when position is determined cut the tape away carefully with a sharp razor or blade. the other way could be to leave the backing plate off just use the latch to set the position then trace  around it with a soft lead pencil remove the latch and fit backing plate.
dean
