June 17, 2025, 08:08:29 AM *
Author Topic: Timing Gear Part Number  (Read 3182 times)
Burnsy
« on: April 30, 2005, 11:14:51 AM »
Can anybody tell me what the part number for a grey motor timing gear is?  I have a NOS gear in a box, the original NASCO Holden box is labelled 7414360 but the gear is stamped 7414429, just wondering why the difference Huh, it is a fibre gear.
Pretty sure it is a grey motor gear as it has 48 teeth and I think red motors only have 46 - can anybody verify?
Burnsy
« Last Edit: April 30, 2005, 12:51:31 PM by Burnsy » Logged
Mike
Martin
« Reply #1 on: May 01, 2005, 10:58:49 AM »
G'day Burnsy.
My Holden parts catalogue lists the timing gear as part no. 7401136.
So I looked in my Rare Spares catalogue and found:
Gear Timing Camshaft Grey Motor Fibre type:  Part no. 7414360.
So it seems you've got the right box, but the wrong gear.
But don't take my word for it - check it out with Rares.
Regards,
Martin
Martin
Marion.  South Aust.
Ebay user id:  lewis1411
Burnsy
« Reply #2 on: May 01, 2005, 11:58:44 AM »
Does anyone know how you can tell from looking at/measuring the gear.  It definitely has 48 teeth the same as the ones pictured in my workshop manual and I counted the teeth on an alloy red motor gear and it had 46.  Changing the number of teeth would change the timing drastically if I am correct in my thinking.
Is it possible that Holden changed the part number at some time.  It also has B.13 24 1 67 stamped into it (the other numbers are part of the molding), I am guessing that these might relate to manufacture date - 1967???
Anyone got a fibre red motor gear that they could count the teeth on for reference?
Confused,
Burnsy
Mike
FE_UTE
« Reply #3 on: May 02, 2005, 01:36:59 AM »
Burnsy...The timing gear 7414429 is a grey motor timing gear...its just an old number
The number was replaced by 7414360 and thats why the box has that number
The one I have taken off my engine has the number 7401137 stamped on it and this is also an old number replaced by 7414360
hope this helps...if not give me a call
Cheers Gary
Burnsy
« Reply #4 on: May 02, 2005, 02:13:22 AM »
Thanks Gary, I thought that might be the case, just wanted to clear it up before I stuck it on ebay and figured that the details may help someone else in the future Wink.
Does anybody know the answer to the number of teeth query  though, it is an easy way to tell the difference if in fact all grey gears have 48 (remember 48 the first grey Grin) and reds have 46 teeth?
If anyone wants it PM me with an offer before I list it.
Burnsy
Mike
FE_UTE
« Reply #5 on: May 02, 2005, 03:22:48 AM »
The grey has 48 and reds have 46 and have a larger centre hole
approx 8mm larger than the grey one and is a couple of mm smaller in size
