June 10, 2025, 02:10:46 AM *
Author Topic: Hand brake cable  (Read 2609 times)
jaunt
onetonner
« on: April 29, 2005, 02:25:15 PM »
I have an fc with HR diff, but the hand brake cable does not reach the handbrake lever mount.  Do i have to use an fc handbrake cable ?. If so how to attach to rear brake drum. :-/
Thank guys.
jaunt
onetonner
« Reply #1 on: April 30, 2005, 12:25:15 PM »
okay, i work it out, just lenghen the cable bracket. Wink
Sarge
« Reply #2 on: April 30, 2005, 06:53:44 PM »
Jaunt
       you could just get a new cable made. I have not done this mod before and am very surprised that nobody has responded to your post. would it be possible to cut the ends off the HR cable and then drill out so you can silver solder them onto the  FC cable?
Sarge
        0421 165 351
Sarge
« Reply #3 on: April 30, 2005, 07:04:09 PM »
Jaunt
       Here you go I thought I had seen something about this recently.
Handbrake cable is made by disassembling the EK and HR cables.  Remove the plug ends from the HR cable that go into the backing plate, cut off the ball on one end of the EK cable and fit the HR plug ends to the EK cable ends.
Punch the wire out of the removed ball and then silver solder the ball back onto the cable.  The 10 mm shorter cable wont make any difference to the cable.
If you have trouble understanding this then give me a call and I will explain in more detail
Regards   Ken
You can find the whole lot in restoration help. Mods for HR front end. It's about the 3-4 down from the top sorry but dont know how to post a link for you to go striaght to it.
Sarge
        0421 165 351
« Reply #4 on: April 30, 2005, 09:18:32 PM »
You can also get a custom set made new here -
http://www.autocables.com.au/
I have a HR diff also, just tell him what you have and he'll make to suit.
Page created in 0.26 seconds with 19 queries.
