August 25, 2025, 03:14:19 PM *
Author Topic: chassis member?  (Read 2304 times)
Jonno
« on: April 19, 2005, 10:48:10 PM »
If anyone is wrecking a vehicle which isn't completely rusty I'm looking for a little section/strip of 'corrugated' metal which sits under the rear LHS floor pan and runs parallel to the length of the car, just inside from the inner sill, presumably giving some strength to the floor pan itself.
This is for a ute but Ken tells me the floor structure is the same as sedan so I think a part from any model will do the trick.
This is to replace a rusty one so obviously a rust-free one is preferred.
many thanks, jon
Cottles Bridge, VIC
« Reply #1 on: April 19, 2005, 11:11:45 PM »
If you can't get one locally, send me a picture of the section you want and I will see if the FC wreck I have is suitable.
Jonno
« Reply #2 on: April 20, 2005, 09:29:08 AM »
thanks Glenn,
will try get a photo next week (car not here at the moment)
Jon
Cottles Bridge, VIC
Jonno
« Reply #3 on: April 20, 2005, 10:36:52 AM »
as luck would have it I found a photo (of 'Doris' on the Tas club site) which shows the very thing I'm looking for. Its the part indicated with arrows...I actually need one for the LHS but they may be the same either side?
« Last Edit: April 20, 2005, 10:38:19 AM by Jonno » Logged
Cottles Bridge, VIC
« Reply #4 on: April 21, 2005, 08:30:21 PM »
I'll check it out this weekend and let you know.
Jonno
« Reply #5 on: April 21, 2005, 08:32:30 PM »
thanks!
J
Cottles Bridge, VIC
