May 18, 2025, 01:24:34 PM *
Author Topic: 132 grey motor oil  (Read 7786 times)
bryan
« on: April 07, 2002, 07:20:17 PM »
HI there can someone tell me what oil i should use in the 132 grey motor? Smiley
« Last Edit: April 09, 2002, 04:41:59 AM by bryan » Logged
PeteR
ampmobile
« Reply #1 on: April 10, 2002, 01:33:51 AM »
Bryan,
Oils are one of those 'horses for courses' things.  However with the older motors, ie red and grey motors, the best oils seem to be the 20W-50 varieties, not the Kmart reconstituted stuff, but from known companies, eg Castrol, Mobil, Shell etc.  Really you can't go wrong, especially if you change at the recommended intervals, 6000 miles if I remember rightly!!
Peter
« Reply #2 on: April 10, 2002, 02:43:39 AM »
Bryan,
Try asking the oil companies. They all have Technical departments who would be more than happy to help.
TRY
www.shell.com.au
www.valvoline.com.au
www.castrol.com.au
Here is a list of Castrol oils including a description.
http://www.castrol.com.au/castrol_001/products/pd_engoil_index.html
I have already sent an email to Valvoline so I'll let you know the response.
bryan
« Reply #3 on: April 10, 2002, 07:20:40 AM »
Thanks guys for your help with the oil,a big help. Smiley
« Reply #4 on: April 12, 2002, 08:31:11 AM »
Hi Bryan,
Heres the answer from Valvoline. It also may be of assistance to other grey motor owners.
"The original GMH specification was API SD 10w/30.  As you can appreciate, there has been some changes since then.  I would recommend you use an API SF monograde 30 engine oil such as our Super HPO 30."
See http://www.eposode.com/fc%20test/1033.pdf for product details.
You will need the Acrobat viewer installed. You can get it for free from http://www.adobe.com/products/acrobat/readstep.html if necessary.
FCwagon
« Reply #5 on: April 13, 2002, 01:57:45 AM »
If you use a single grade oil you should be matching it with leaded petrol. As this is no longer available you should use a good multigrade and change it every 1,000 miles.
Red & white is alright
