September 09, 2025, 03:47:39 PM *
Author Topic: Brake lights or taillights but not both....  (Read 2045 times)
paddockbasher
« on: March 18, 2005, 12:08:58 PM »
Am having issues getting brake and tail-lights to work  together.
Brake lights work fine however I have no taillights. If I run power directly to the terminal on the light switch the taillights work however there is no discernable difference when the brake pedal is pushed. Are they two separate circuits ?
Any help much appreciated! Have the workshop manual with wiring guide but obviously written for a higher intellect  Cry
satch56
Life's not that hard
« Reply #1 on: March 18, 2005, 01:31:07 PM »
Going by the circuit the brake lights and the indicators share the same circuit for each side the LH (Pink Wire) and RH (Violet Wire). The LH & RH tail lights are powered from a common circuit (Black Wire). Are you sure you're not powering the brake lights by mistake, or may not have double filament globes or globes fitted wrongly.
Hope this helps.
satch56
paddockbasher
« Reply #2 on: March 18, 2005, 10:23:12 PM »
Thanks Satch
Now working!
