August 28, 2025, 09:38:11 AM *
Author Topic: BOOT-MOUNTED AIR CONDITIONING EVAPORATOR  (Read 7418 times)
Chuck
Finished!
« on: March 14, 2005, 10:59:31 PM »
Hi All
I am trying to locate a second hand boot mounted air conditioning unit (i.e. the evaporator).
I was speaking to Dr Terry last week and he mentioned that a company in Queensland once manufactured this style of unit for taxis.  They were unique in that they had an unusual air intake/exhaust system (the intake/exhaust ducts resembled two speaker grilles in the rear parcel shelf, air was drawn in through the centre and exhausted around the outside – or vice versa, I can’t exactly remember).
As fas as I know, a member of this club has successfully fitted one of these units to his sedan.  If anyone has any photos of the boot of this car, or indeed the unit, could you please send them to me or post them here.  Additionally, if anyone is aware of such a unit in a wrecking yard, or if you have one that you are willing to part with, could you please let me know?
Cheers - Chuck
Fast_Eddie
« Reply #1 on: March 15, 2005, 06:49:14 AM »
I maybe able to find one, but will need about 7 days solid work on a particular Station Sedan in exchange.
Fast_Eddie
« Reply #2 on: March 15, 2005, 06:49:35 AM »
In advance Grin
NO NAME
« Reply #3 on: March 15, 2005, 01:02:40 PM »
me too,
not sure if this will help but suss out 79-86 toyota crowns, open the boot and remove the carpeted panel under the parcel shelf.
Chuck
Finished!
« Reply #4 on: March 16, 2005, 09:12:08 AM »
I'll be right over, just waiting for the little pink fellas with curly tails to fly past and I'll be on my way.
Hey Leon
Thanks for the tip, I went to Pick n' Payless at Blacktown today and removed the rear air conditioner from an 86 Cressida.  Great looking unit but unfortunately too large for an FC sedan.  Also, the configuaration of the ducting would make it slightly difficult for the application I have in mind.  Worth a shot though.  I will continue the the hunt!
Chuck
tmudie
Back on the road again
« Reply #5 on: March 16, 2005, 10:50:44 AM »
Hi Chuck,
if youre interested I have a real nice Mark IV under dash unit, is complete and was working out of a early 70's Peugoet 504. Doesnt look too out of place, they were fitted up to early 60's cars. The fans and evaporator etc are all built in to the one unit and it will fit nice and snugly in the centre of the dash.....colder than a mother in laws glare.......Have the condensor, compressor etc, although I'd imagine youd want to hook up a newer unit and fabricate a bracket.
Tony
0402 891 337
NO NAME
« Reply #6 on: March 17, 2005, 12:22:06 PM »
Quote from: Chuck
Hey Leon
Chuck
man we must have been so close to crossing paths today.
are you sure it doesn't fit becuase anything fits if you bang it hard.
If I knew you were close to blacktown I would have recomended pick & pull at seven hills, I think blactown has 4 in the 86 shape of the cressidas but seven hills pick & pull also has about 3 crowns.
I know the unit is packed tight like a v12 jag engine bay but maybe you could shuffle things around, also there is some interesting vents and ducts as they have ducted ac in the roof, air purifier and drink cooler.
« Last Edit: March 17, 2005, 12:33:10 PM by FCCOOL » Logged
Chuck
Finished!
« Reply #7 on: March 17, 2005, 08:32:43 PM »
Hey Leon
I almost always use Pick n' Pull at Seven Hills, in my opinion the best wrecking yard in Sydney, really easy going guys and plenty to choose from - they just didn't think that they had any Toyotas with the setup left in them.  I took a few photos of the unit out of the car and I will continue to think about how I might be able to make it fit.
Chuck
« Reply #8 on: March 18, 2005, 05:49:03 AM »
Hey Chuck.
I find this idea very interesting.
How about sharing those pics.
Good luck with the hunt.
Chuck
Finished!
« Reply #9 on: March 18, 2005, 09:30:35 AM »
Hi Alex
No problems, to be specific, the unit is from a 1983 Toyota Crown.  I was quoted between $30 and $50 (not sure at what end of this scale though).  I have more pictures if required.
Chuck
Chuck
Finished!
« Reply #10 on: March 18, 2005, 09:33:07 AM »
OK, will try again, don't know what happened then.
« Reply #11 on: March 19, 2005, 01:06:10 AM »
Try renaming the file so it doesn't have special characters in it, like the parentheses.  The attachment function doesn't seem to like non-alphanumeric characters, ie stick to letters, numbers, underscore, hyphen and dot.  Avoid spaces, quotes, commas, any brackets and punctuation like !,@,#,$,%,^,&,*
Chuck
Finished!
« Reply #12 on: March 19, 2005, 04:56:59 AM »
Thanks RET, third times a charm - I hope  Wink
« Reply #13 on: March 20, 2005, 07:04:13 AM »
Wow. That was not anything like I was expecting. I see why it wouldn't fit in the boot of the FC. Let us know if you find 1 that fits. Thanks for the pic.
How close in measurements is it?
How does it work?
Chuck
Finished!
« Reply #14 on: March 21, 2005, 10:50:19 AM »
Hi Alex
The only thing that I forgot to take to the wreckers was a tape measure!  However I could tell just by looking at it that it was going to be too large for my application, even when significantly modified, especially considering that I have wheel tubs, an extra large battery box and restrictive timber panelling. The boxed area behind my back seat the already accommodates the battery and it will be far too small for a unit of this size.  In a sedan with a standard boot configuration, it may have a chance.
It has an unusual system of operation.  The rear parcel shelf has two large flush fitting panels, the one on the drivers side is the intake (the large rectangular hole on the right side sits directly below this).  Below this is the grey draw that contains a large serviceable paper element like an air cleaner element on a modern car).  Air passes from the intake chamber through a large duct (the white tube running along the base of the unit) and into the fan where it is energised and passed through the evaporator core.  It then passes into the large styrene lined chamber in the middle.  This top of this chamber sits directly below a second flush fitting panel in the middle of the rear parcel shelf.
Hope this helps - Chuck
FCwagon
« Reply #15 on: March 22, 2005, 02:38:16 AM »
This unit in the Crown was nothing more than a grossly over-engineered esky. The drink container part was located on the rear parcel shelf, so when the car was left in the sun for a few hours your drinks got hot agin.
cheers,
Leigh
Red & white is alright
NO NAME
« Reply #16 on: March 25, 2005, 10:21:38 AM »
have you tried units from plusho vans like 83 on tarago GLI. they usually have a seperate unit for the rear.
