August 27, 2025, 06:58:16 PM *
Author Topic: electrical problems  (Read 3413 times)
utey
« on: March 14, 2005, 01:58:25 PM »
Just refitted the dash and switches and now have no dash lights, indicators and the headlight dim when I turn the * rheostat ( the combination light/dash light dimmer switch)
*correct name spelling?Huh
Any advice
Nick
smithy
yeah its purple !
« Reply #1 on: March 14, 2005, 10:06:37 PM »
hi nick, ah the joys of electrical problems, sounds like your headlights may be hooked up to the wrong terminal, try these links here they go into some good detail
http://www.fefcholden.org.au/cgi-bin/yabb/YaBB.cgi?board=howto;action=display;num=1091145598;start=0
http://www.fefcholden.org.au/cgi-bin/yabb/YaBB.cgi?board=howto;action=display;num=1076486159;start=2
your indicators could be caused by a bad earth, i found this out recently where one of the rear blinker globe holders wasnt contacting the housing properly, or could be bad flasher can. good luck
dean
« Reply #2 on: March 15, 2005, 12:11:18 AM »
good stuff Dean,
I was just after this info.
Would anybody know how to remove the headlight switch/rod?
Does the spring button have anything to do with it?
Any help is much appreciated.
smithy
yeah its purple !
« Reply #3 on: March 15, 2005, 12:26:23 AM »
hi ed, pull the headlight knob /switch all the way out as you would to turn your headlights on then depress the spring loaded button on the switch body and pull.
simple  Grin
dean
utey
« Reply #4 on: March 15, 2005, 07:12:32 AM »
Thanks Dean
Pulled the switch apart and cleaned the contacts, had to rewire as the coiled resistor was bust.
Dash lights working, head lights dimming.
The link to Martins post was great.
Just the indicators to sort out now.
Nick
smithy
yeah its purple !
« Reply #5 on: March 16, 2005, 09:53:16 PM »
hey nick, good to hear you sorted out the lights, what is the problem with indicators as i have just sorted out some problems with mine and may be able to help?
d
utey
« Reply #6 on: March 17, 2005, 03:00:24 AM »
Dean
No indicators at all, working ok before I pulled the dash and lights.
Will check to see if there is power to bulbs then work backwards.
Nick
"If it was easy would it be so much fun"
Al
I love FC Ute's!
« Reply #7 on: March 17, 2005, 09:27:57 AM »
Nick,
        Try the wires on the blinker can or try another can.
   Cheers Al
See ya
Al
Page created in 0.034 seconds with 18 queries.
