May 17, 2025, 01:54:51 PM *
Author Topic: Lowering FC  (Read 9062 times)
TAYZ
« on: February 14, 2005, 12:55:27 PM »
Want to lower my FC as it is sitting like a 4wd.  Not sure at this stage how to go about it, dont want to cut the springs.  Can anybody give me some suggestions?  I want to drop it about 2-2and a half inches.
normd
6 in a row , the way to "GO"
« Reply #1 on: February 14, 2005, 03:58:52 PM »
Hey Taz
  Probably  the first step is to visit suspension specialists , they would have a pretty good idea what size coils for the  front so you can get a lower  ride but it won't "bottom out" and get  the rear leaf springs re-set or lowering blocks (but don't know if they're still legal these days)
  Norm  Smiley
« Reply #2 on: February 14, 2005, 09:19:37 PM »
If you are handy with cars, call your nearest spring maker for your options. We have one in SA called Industrial Springs, they even install the springs if you want they probably deliver interstate too. Or call a suspension specialist.
If you don't want to do the work, call around ALL the local suspension specialist for prices on supply and install. They would generally be selling the same gear when it comes to springs.
A more expensive option is the Rod Shop drop spindles at about $500 a pair.
Cutting springs and lowering blocks are not an option if you want to stay legal.
Blown_FC
« Reply #3 on: February 14, 2005, 11:03:03 PM »
I have a HR Front End in my FC...so it was as simple as buying a set of lowered springs to suit a HR  and for the rear, I sent my original leaf springs off the Westralia Springs in Belmont ( WA ) who pulled them apart, cleaned them, hot dipped and reset to 1" lower and then painted and reassembled with new nylon bushes all for $140.
SHe looks low now, and that's with no motor, glass, interior, fuel or battery and that's sitting on 13" wheels.....can;t wait til I fit bigger wheels and see the car at kerb weight !
Mark
« Reply #4 on: February 19, 2005, 09:57:47 AM »
Lowering blocks are OK in Vic, my car went through both engineering and RWC with 2 inch blocks fitted
NO NAME
« Reply #5 on: February 22, 2005, 01:34:14 PM »
I was told to lower my car when I went for engineering, I had taken out my cut springs and put in some real tall ones out of stuff knows what but the tall springs made it very difficult to control.
on the rear I started of with 2" lowering blocks but was not satisfied.
I ended up changing to 1 1/2" blocks, I had the eyes reversed on the springs and then got them lowered a further 3".
I then coul't get in the driveway so I fitted airshocks and a compressor.
Graeme
« Reply #6 on: February 22, 2005, 09:12:03 PM »
G'day Tayz,
I am also in Ballarat and have a fc wagon well under construction.  I have some spare lowering blocks that would suit you if you want to try them.  Send me a message here if you want to grab them to try out.  I also have the address and details of a place in melbourne where i got my rear spirngs reset.
Graeme
TAYZ
« Reply #7 on: February 23, 2005, 11:33:23 AM »
Thanks Graeme,
                        I reneged and put it the two inches at the rear.  Then by some sort of magnetic force I lopped a coil and a half of each side at the front and it is sitting pretty nice(for the time being anyhow, maybe another inch?)
« Reply #8 on: February 23, 2005, 12:39:50 PM »
Tayz, have ever seen the Ricers getting around in their way too low, cruddy, beaten up jap cars and they are bobbing around like one of them noddy-dogs?
That's the quality of ride you will be getting with the cut springs, I'd suggest a set of properly lowered jobbies.
Your kidneys will love you for it  Grin
Shayne
Just Cruisin'
« Reply #9 on: February 23, 2005, 11:24:47 PM »
Gday Stinky,
I realize that cut springs are a no-no, but there is more to ride and handling than just springs.  My wagon had cut springs in it when I bought it, and for that reason, was very dubious about the handling.  Everything else in the front end was in good condition, and it actually rode and handled better than most early Holdens I've driven.
Having said that, if you had the choice between cutting springs and resetting them, go resetting every time.
HARKO
« Reply #10 on: February 24, 2005, 03:07:13 AM »
Nothing wrong with cutting springs ,Just dont do it with heat ! No Oxy because it will weaken the spring.
Use a hacksaw if your extremely keen or a 1mm grinding disk works a treat ,Doesnt even burn paint on sheet metal so the heat wouldnt be a problem.
Ive been running the same cut springs for 6 years and they havent sagged ,They are v8 commodore although once cut down have probably brought it back to EK specs just lower.
They sit about 10mm off the halved bump stops - so they are extremely low for an original front end.
« Reply #11 on: February 24, 2005, 05:22:51 AM »
Hey Harko,
Your FB does have a nice stance and for all intense purposes you have had no troubles but...
A manufactured spring has a flat machined into the seating surfaces, by cutting springs you remove this feature.
This feature ensures that the weight of the vehicle is supported by more than just the tip of the spring only.
Removing this may over stress the spring at the end and cause it fail.
Losing half to one inch of spring all of a sudden on cut down bump stops may not be every ones idea of fun!
Im sure your awesome projects dont have cut springs! Your grey powered beasty is in a differnet categoy right?
Sorry mate, that's just my opinion on spring cutting.
« Reply #12 on: February 24, 2005, 06:52:21 AM »
Each to their own, just offering an opinion.
Now changing to my english teachers hat...
Isn't the saying
"for all intents and purposes" ?
sorry Ed, thought I'd point it out before someone else did.
HARKO
« Reply #13 on: February 24, 2005, 12:42:29 PM »
Early springs dont at both ends ED or mine didnt atleast ,the recess in the bottom control arm has .
You know if something can be cut - its worth cutting . Grin
« Reply #14 on: February 24, 2005, 09:33:47 PM »
I stand corrected Stinky... * pauses, hits grammar, spell check and correct use of English button*   Grin
ok Harko .. cut the bloody things!
A previous car of mine had all cut springs, and it wound up through a fence...  always wondered if the cut springs had anything to do with it!
Grin
NO NAME
« Reply #15 on: February 26, 2005, 06:41:19 AM »
when you see these guys bobbing up and down it's prrobably half real and half acted or exagerated.
some people think its cool to bounce around when cruzing along, you will probably notice once they get of main street or think they are out of site they wont be so bouncy.
this isnt new to todays young generation, it has probably been cool to do this in parts of the world since before FE's were tadpoles in their dads -
dont you old guys remember watching the early cheech and chong movies?
In places of the US were cruizing was big in the 50's we were seeing customs 1" of the ground. if you were a parent of a teenager you would relax if your kids left in a kustom as the low clearance and heavy led meant they wouldn't be going anywere fast. they didn't need too, they looked more cool at 2 mph.
on the other hand, hot rods were built for speed, un necessary items were removed to reduce weight, bigger motors were fitted etc, this probably meant your kid was going out for some street racing.
if you go low more than 5 inches you will end up with your tailshaft hitting the floor under acceleration. I know from years of experience, my car has never jumped of the road but it has chewed a few uni's.
anyone who has seen it parked along side another FC has commented on its low roofline and bumpers.
if you want to persue handlin buy a ferrari, if you cant afford one buy a datsun 1600, if you want to look cool buy some thing 50's and dump it in the weeds, more than likely you will only experience hassles if you cant drive for shit, live on a corragated road or you cant figure out the new characteristics of your cut springs and try taking bumpy bends at high speeds.
possibly one day your stocker fe or fc may end up on its lid if you dont drop it. dont bullshit me, ive driven quite a few stockers on todays roundabouts and it dont seem to safe.
normd
« Reply #16 on: February 26, 2005, 05:21:23 PM »
Hey Guyzz
  Is this about the right height ?
 Just high enough to poke the exhausts out the side  Grin
if you look at the centre of the wheels compared to the sill you'll get the idea.
  Rear springs were re-set and are dead straight , don't know how many coils were cut off the front springs , but not many coils left there  Grin   (they were cut before I bought the car) and this one is a REAL kidney killer.       ( word of warning , don't try to cross speed bumps in carparks , it tends to "grind" just a little  underneath Roll Eyes
 It corners great at 100 mph
  Norm  Smiley
PS . It is an FC ..  just an FE grill for better Airflow..
Sarge
« Reply #17 on: February 26, 2005, 09:27:16 PM »
Hey now be nice not to much of the old.
Sarge
        0421 165 351
Burnsy
« Reply #18 on: February 27, 2005, 02:03:31 AM »
Having talked about buying a new set of lowered springs so the car looks better in the wedding photo's next week but not currently being able to justify the expense I bit the bullet after reading all this and lopped one and half coils off each side last night.  I will get some reset ones eventually - after the grey is finished, but hey I am happy with the ride height and ride now Grin.  It corners much better and no doubt would be again improved with reset springs.
Harko you are right about only one end of the springs being machined.  I included the big grinder Grin Grin Grin in the picture just to excite you mate.
Mike
blacky
« Reply #19 on: February 27, 2005, 03:59:32 AM »
 Looks good Burnsy , just throw a few bags of cement in the boot and youre good to go .... might handle a bit iffy though.
When I was much younger and a bit sillier the standard method of lowering old holdens comprised of four simple steps ...
 1) Remove both front springs
 2) Cut one in half
 3) Throw the other one away
 4) Reinstall  Grin
Page created in 0.038 seconds with 20 queries.
