June 17, 2025, 04:23:50 AM *
Author Topic: Hoodlining  (Read 2499 times)
TAYZ
« on: February 13, 2005, 09:08:17 AM »
Got Fc home today and had a good look over it.  It has been sitting dorment in a shed since cocky was an egg and needs a good clean.  The hoodlining is in good nick but needs a good clean.  I am wondering what to use to clean it as it is pretty delicate?  Any suggestions?  Also it has a bowman heater in it and it looks brand new.  I have not come across these before, can any one shed some light on it please?
FC0058
Jim Altmann
« Reply #1 on: February 13, 2005, 09:46:08 AM »
Hi Tayz
Not to sure what you should use to clean your hood lining, but would not mind seeing a photo of the heater, as I am with you I have never seen a Bowman heater.
Cheers Jim
TAYZ
« Reply #2 on: February 13, 2005, 07:01:40 PM »
As soon as I stop working(got a bit on) I will take some pics of the car, especially the heater and post them on the site.  The old girl runs like a beauty apart from a few small hiccups
fe2ek
« Reply #3 on: February 13, 2005, 09:10:13 PM »
Wait until you get some replies as if you wet your headlining too much you could stuff it.Some of the Gurus out there will tell you what to do.
I have used "disol"with a small nail brush,did a small bit at a time,then towel dried it straight away,then did the same again with a wet rag to get the chemicals off then towel dried again.I just took my time and did a bit every night,but always let it dry and be careful of the stitching.Dont rub too hard as you can stretch the headlining.
Cheers Geoff
TAYZ
« Reply #4 on: February 14, 2005, 01:50:28 AM »
Thanks Geoff,
                      Will keep that in mind, sounds like a good job the missus can help me with!!  I still cant find any info on the Bowman heater(It still looks brand new)
2brite
Cruizin's devine in a '59
« Reply #5 on: February 14, 2005, 04:44:41 AM »
Hi Tayz,
If the car has been sitting in a hot tin shed for a long time i wouldnt be using any chemical cleaners on the hoodling or any harsh rubbing.
I would just use some mild warm soapy water with soft sponge or rag doing a little patch at a time and wiping it with clean water as you go along.
My 2 cents worth ,Goood luck
Cheers Nunzio Smiley
