May 18, 2025, 12:35:48 PM *
Author Topic: Wheel Sizes  (Read 4247 times)
griffo
« on: February 04, 2005, 07:30:41 AM »
Can anyone tell me if their is a difference between
HT, HK & HG rims ?
I want to fit 14 in. steelies to my HR front end and was
wondering which would be best !
Griffo.
fcstationsedan
« Reply #1 on: February 05, 2005, 02:19:22 AM »
HK are different because they have slots in them, from memory four lots of two together (8 slots in all) but are becoming quite hard to find. I think they are 14" x 5". HT and HG are standard looking rims, like a 14" version of an HR rim.
I believe some (such as Monaro) may have had factory 6" wide? Widened rims in HK-T-G were quite common (aftermarket) and come up for sale at swap meets. Volvos also used the same stud pattern for many years (now changed) and have a choice of different rims available. Personally I like the HK and have a full set (including widened rears) on a 29 Chev project I have (runs early holden stubs and diff).
My FC currently runs 14" mags but I find the tyres touch on full lock occassionally. I will put lower profiles on when I change them, I thought of going to a set of stock HK-HT-HG rims as I have a set of 14" whitewalls here but was concerned that the tyres were too tall and foul. Low profiles are a better option.
Former 1959 FC Station Sedan owner.
Fast_Eddie
« Reply #2 on: February 05, 2005, 02:34:13 AM »
I also believe the offset changed between HK - HT - HG.
They will fit an HR front end, however the FC hubcaps will not fit.
« Last Edit: February 05, 2005, 02:35:39 AM by Fast_Eddie » Logged
colt
act-club
« Reply #3 on: February 05, 2005, 07:19:53 AM »
HT & HG had a 1 inch? wider track than the HK. The difference was made up in the rim offset.
Colin
colt
Dr_Terry
« Reply #4 on: February 05, 2005, 07:50:11 AM »
Hi guys.
The wheel nuts are also different.
The HK used the same as FE - HR & the HT/HG used the later style.
Dr Terry.
griffo
« Reply #5 on: February 05, 2005, 09:21:03 PM »
Thanks for replies
So which one is the best ?
HK or HT -G with the wider offset , do the tyres then rub or do you still have clearance ?
Does anyone have these fitted ?  and with what tyre
Griffo.
Fast_Eddie
« Reply #6 on: February 06, 2005, 09:25:27 AM »
Send a PM to "Chuck". He has fitted HK and HT/G wheels to FC's (for reasons only known to himself  Wink) and he will be able to explain the advantages of both.
When discussing his current project recently, he mentioned something about wishing he'd used HK rims again instead of HT/G because of the offset, however I don't think it was because of a clearance problem.
SRVLIVES
« Reply #7 on: July 04, 2005, 10:58:33 AM »
I've just picked up a pair of 14x7 HK rims, anybody running these on the rear of their sedan and what size tyre are you using?
« Reply #8 on: July 04, 2005, 11:14:35 AM »
I have some 14x7s on the FE Sedan with 235/60(?) Firestones not 100% on the profile. Yet to be road proven though and I had the rims made to suit so they may have a different backspace/off-set to yours.
Page created in 0.03 seconds with 21 queries.
