May 26, 2025, 12:01:13 AM *
Author Topic: Camshaft swap  (Read 9956 times)
Dave_EH
Keep on Holden' on
« on: January 20, 2005, 11:18:37 AM »
Hi,
I presently have an unused cam (from an unstarted donor motor) that I have been intending to have put into my low milage stocko 179.
I was told by the seller it was a "30/70" cam, advanced 2 degrees (I assume that means its asymetircally timed?)
The spec sheet reads as: SAE (.006" Cam Lift) Cam Timing
               Duration  Opens   Closes   Overlap
Inlet:        281           32         69          61
Exhaust:    281           72         29
It is a powerboss - part no. CS-1277
Can anyone decode these specs and verify the Cam?
From what I have picked up from using the forum, I now believe this cam may be a little lumpy for a daily driver.
I'm running a 2.7 diff.  I'm considering swapping the cam for something a little milder.
I'm after any opinion on:
1)what cam to use
2) whether it can be installed by removing the front grill rather than pulling out the engine - in order to save some dollars in workshop time...dialing in a cam is somehting I doubt I will ever try.
Looking forward to your thoughts
Dave Huh
« Last Edit: January 20, 2005, 11:19:22 AM by Dave_EH » Logged
fccool59
« Reply #1 on: January 20, 2005, 11:35:07 AM »
30/70 should go fine with a 2:78 and 13" wheels
HARKO
« Reply #2 on: January 20, 2005, 11:35:28 AM »
Dave ,A mate had a 35/75 in a 3 speed HR and it was a pig to drive.
Also a mate runs a 30/70 with a celica 5 speed in an EH and its noticeable that its lumpy and has a noticeable power increase in its rev range when the cam starts to work.Id say its a bit lumpy to run an auto  transmission behind .
If you do decide on a swap Ive got a very mild cam in a 3000 klm 186/192 that id be willing to trade but will need a week or so to pull it out of the engine.
I will have a look for the spec sheets on the engine to find out its grind.
I guess yours being 32/72 it will just slightly lumpier than the 30/70
« Last Edit: January 20, 2005, 11:38:19 AM by HARKO » Logged
Dave_EH
Keep on Holden' on
« Reply #3 on: January 20, 2005, 11:46:37 AM »
Hey Harko,
I'm just running a 3 speed crash on the column.
I'be heard a 30/70 doesn't really start to pull till about 3000-3500 rpm which may be a little too high for an unbalanced red backed to a crash box.
so mine IS a 32/72? Being advanced would make it even more lumpy?
I'm in no real hurry - I would have to take my engine to a mechanic to have the cam pulled out for you as I have never done it before, so let me know how you're going when you find out the grind.
I've never driven an old holden - not even my own yet - so am trying to get the thing right from word go.
I'm really just after a nice sounding idle throb and something that has a little top end and a good mide range and take off.
Any ideas on installing the cam with the engine in the bay?
« Last Edit: January 20, 2005, 11:51:36 AM by Dave_EH » Logged
HARKO
« Reply #4 on: January 24, 2005, 12:38:10 PM »
Sorry Dave Ive never actually changed one in the engine bay ,Can anyone else help out here ,I would think that the grille is a pain to remove/install if need be.
colt
act-club
« Reply #5 on: January 25, 2005, 06:11:30 AM »
You can change the cam with engine in place on FE/C with grey motor. Remove grille, radiator. Lift front of motor slightly to clear subframe front rail.
Colin
colt
ChrisB
"Shiny Bits"
« Reply #6 on: January 25, 2005, 09:16:08 AM »
Yep sure can change it in the car, but you also will need to undo the gaurd bolts to get the grille out without chipping the paint.
Having done it I certainly would not do it again as I was advised in the first place. I did it in the car as I did not have an engine crane.
I have since bought a crane and grey motor lifting frame. It made the job much easier when I had to rebuild the old grey. With the proper frame the grey comes out so so easy, about an hour or two and its on the deck.
ChrisB   Cool
Al
I love FC Ute's!
« Reply #7 on: January 25, 2005, 01:09:46 PM »
          I always use a 25/65 grind cam with the 3.08 diff in the red motors or a 3.36 diff ratio behind the grey motors. If you use the 2.78 diff with the 3 speed it will be a lot harder to take off which will put a lot more strain on clutch and drivtrain. You can change the cam with motor in the car I,ve done lots of them. Do what Colin said .
      Cheers Al
See ya
Al
Dave_EH
Keep on Holden' on
« Reply #8 on: January 28, 2005, 08:48:10 AM »
Appreciate the the help... all taken onboard!  Harko, I may contact you abou that cam, or let me know when you find the spec sheet.
HARKO
« Reply #9 on: February 17, 2005, 01:06:53 PM »
Hey Dave the cam I have is a lumpy aswell aparently so Id say give it a miss .
Anyone else keen to help please do !
CHO 576
« Reply #10 on: February 17, 2005, 10:36:00 PM »
I've got a similar problem/issue.
A mate did my grey motor up a few years ago now (free of charge).
However, he dropped a new cam in that is just a little bit lumpy. It has a nice little throb when idling, and very good performance up high (not sure of the exact specs of the cam though). Taking off from a standing start though is a bit of a hassle - I have to give the car a bit of petrol before it will even move (definately not a nice smooth takeoff)
Unfortunately, I have brougt the car back to be stock all round - so would really like to get the Original cam back in.
Is there anywhere I can $$$ buy a (new) 'original specification' grey motor cam?
thanks ...
J
Dave_EH
Keep on Holden' on
« Reply #11 on: February 25, 2005, 10:57:20 AM »
Thanks Harko,
I went down to my local engineering shop where they do camshaft grinds and headwork and had a chat.
They are happy to swap my unused cam for another milder one and said that a 32/72 is "drivable", but with a 3 speed it would be fairly ordinary except for putting your put down in 2nd or 3rd gear.
As i get further into the project I'm beginning to think less about pulling wheel stands and more about a nice cruiser Grin
I really just want something with a nice idle throb and some get up and go through the midrange.
