August 29, 2025, 02:28:09 PM *
Author Topic: By-pass oil filter  (Read 2221 times)
Martin
« on: January 18, 2005, 01:19:40 PM »
When I refit my motor I'll be attaching a by-pass oil filter.
As I bought the filter without any plumbing, I've got little idea where it plumbs into.
I though it would plumb into a tee-piece screwed into the oil pressure light switch hole near the dizzy, but a fellow told me today the take-off should be through the other hole just above the oil pressure switch.  This is currently plugged with a largish grub screw.
So, where is the take-off?
And where should the return line go?  Just behind the fuel pump is another grub screw, and below it a slightly larger hole blanked off with a small hex-head bolt.  Which one of these is the "return" hole?
Thanks for your help.
Martin
Martin
Marion.  South Aust.
Ebay user id:  lewis1411
EJ_Dave
« Reply #1 on: January 19, 2005, 02:00:33 AM »
The inlet of mine is attached to a T-piece in the oil pressure switch hole. I hadn't thought about the grub screw above it as an option. Maybe that would work too. The return goes into the lower of the two holes just behing the fuel pump- where the hex bolt is on yours I guess. Again I'm not sure what the grub screw above is for.
David
Martin
« Reply #2 on: January 19, 2005, 02:07:37 AM »
Thanks, Dave.  Sounds good to me.   Smiley
Regards,
Martin
Martin
Marion.  South Aust.
graham_fuller
« Reply #3 on: January 19, 2005, 02:32:29 AM »
Hi Martin,
My filter is the same as Daves.Infact I think the Motor reconditoner drilled my Willsonia / oil switch adaptor to fit mine.
Martin
« Reply #4 on: January 19, 2005, 10:22:44 PM »
Thanks, Graham
Martin
Marion.  South Aust.
