August 29, 2025, 02:28:06 PM *
Author Topic: Fitting the Boot Lock  (Read 3828 times)
« on: January 17, 2005, 09:22:34 AM »
Is there an easy way (or any way for that matter) to fit the boot lock.
For the lock to sit flush with the panel (not using the boot trim) I have ground off two tabs on the lock and filed the boot lock hole a little larger, to compensate I made a spacer that fits on the inside behind the panel. It would seem that you need a colonoscopy scope (bum camera) and child's hands to fit the bugger though.
smithy
yeah its purple !
« Reply #1 on: January 17, 2005, 09:59:41 PM »
 hi stinky, went through the same problem, i used a boot lock from a EJ/EH sedan,  i found i still had to carefully file out a small section of the hole in the boot for the two tabs ( on the lock body to slot into) and grind / cut off approx 1 inch from the end of the lock. the tail peice that mates up with the mechanism. perfect fit!
hope that helps.
dean
« Reply #2 on: January 17, 2005, 10:41:35 PM »
Thanks Dean, it's gettting the clip onto the lock to hold it into place that is the problem. I have ground two of the tabs off the lock body and filed the boot hole a couple of mm.
It all sits fine and works, but getting the clip on the back of the lock is hard part.
« Reply #3 on: January 18, 2005, 01:22:23 AM »
It sure is!  Definitely not a job for when you're tired or feeling a bit impatient.  Just think, some poor bastard spent all day every day doing this job at the factory...
Very easy to remove, and a right pain to put back in.  You really one hand to keep the lock barrel in place, a skinny hand through the access hole to keep the locking plate square, and a third hand to give it a bit of a whack with something.  Once it grabs on to the lock it's a lot easier just to tap into place.  It's getting on with enough of a hold in the first place, of course...
smithy
yeah its purple !
« Reply #4 on: January 18, 2005, 02:06:11 AM »
sorry bout that i now know what you were asking.
urgh, monday mornings
yeah not a fun job i think i ended up walking away 3 or 4 times.
good luck
« Reply #5 on: January 18, 2005, 03:21:33 AM »
I bet they kept anything heavy out of reach of that guy! Still, one of those locks could do a fair bit of damage if thrown properly  Grin
I have already walked away twice, but I have the third hand issue solved with a clamp. I just need a skinny hand now.
« Reply #6 on: January 18, 2005, 05:45:35 AM »
Getting back to the factory bloke, a tool that holds the perpendicular edge of the retaining clip would make an easy job of this.  If it was done before the boot-lid was fitted to the body, the boot-lid could be stood up in such a way that the lock drops in vertically, meaning one less hand would be required...
