August 29, 2025, 02:30:22 PM *
Author Topic: Steering Column Plates  (Read 1934 times)
« on: January 12, 2005, 01:32:42 AM »
When refitting the steering column/firewall plates, should I be using some sort of sealer?
Fast_Eddie
« Reply #1 on: January 14, 2005, 06:01:11 AM »
Stinky,
Anything to keep out the fumes. Otherwise your cabin will become...er...Stinky!
The original plates had a rubber around the perimetre, as well as one around the column.
The column one is still available from the usual outlets.
If you weren't wanting to remake a rubber for the outside edge, I would use a windscreen type sealant, rather than an adhesive sealant, as you will have great difficulty removing it at a later date.
Same applies for the gearbox inspection cover, however, from memory you no longer have one!
Edward
« Reply #2 on: January 14, 2005, 08:39:11 AM »
Thanks Eddie, I was starting to think I was being shunned  Huh Although with a nickname like Stinky, I'm kinda used to it  Grin
leon
My FC Business Sedan
« Reply #3 on: January 14, 2005, 09:44:49 AM »
 Smiley G Day stinky.
I went to clark rubber and found just the right U shape strip that would just wrap around the two half plates nicely once I postion the plate and start inserting the screws and just be for they start to tighten I fit the U shape rubber  channel around it  and cut of the remander and proceed to tighten the screws.
Regards. Leon. Wink
« Reply #4 on: January 14, 2005, 11:43:56 AM »
Thanks Leon, sounds like a plan.
