August 29, 2025, 02:26:10 PM *
Author Topic: FC Doesnt start  (Read 5080 times)
fe2ek
« on: January 01, 2005, 06:16:28 AM »
Old Fc wont start,wont turn over,not even slow.Good battery,new leads.Red idiot lights come on brightly when i turn the key and the headlights dont work but the parkers do.Any thoughts?
Cheers Geoff
ChrisB
"Shiny Bits"
« Reply #1 on: January 01, 2005, 06:37:12 AM »
Hi Geoff,
How long as the old girl been sitting, and is the motor able to be turned over by hand ?
Next thing I would look at is to see if there is 12Volts at the starter solenoid, this should tell you if your starter or electrics are #uggered, also check the earthing of the battery and motor to the chassis. Originally this was done as negative of battery to water pump mounting bolt and from gearbox across to body. I have seen alot guys put an earth from the battery to the body as well as the motor and do away with the one at the gearbox
Hope this helps
Happy new Year
ChrisB   Cool
« Last Edit: January 01, 2005, 06:37:41 AM by ChrisB » Logged
« Reply #2 on: January 01, 2005, 06:38:16 AM »
Do you get a click from the starter solenoid?
Maybe the starter/solenoid is dead
Was the car outside or in damp conditions?
Check all your important connections and earths especially around the starter and dizzy, maybe give them a clean just to be sure.
colt
« Reply #3 on: January 02, 2005, 08:51:42 AM »
Geoff,
Do the things that Chris has suggested. MAKE SURE that your battery is ok. You can have 10volts on your battery, which is enough to power small bulbs, but not enough to turn motor over.
Colin
colt
fe2ek
« Reply #4 on: January 02, 2005, 11:43:55 AM »
Battery is ok,starts EK fine.Have 12v down to solenoid when key is turned.Gave starter a belt and it tried to turn but didnt sound right,so i think starter is RS.Will check the lights problem next.
Thanks Geoff
ChrisB
"Shiny Bits"
« Reply #5 on: January 03, 2005, 09:56:32 AM »
Geoff,
If the EK has a grey motor, through the starter into the FC, I am pretty sure they are the same.
ChrisB  Cool
Michael
« Reply #6 on: January 04, 2005, 11:08:31 PM »
I had the same thing with my FC and found the hand brake cable was shorting on the dip switch
Michael
fe2ek
« Reply #7 on: January 10, 2005, 09:29:35 AM »
She starts now thanks to a replacement starter from Tony Galea,but  headlights dont work,parkers however do.Where is the fuse for the headlights as apart from the switch,what else could it be?
Cheers Geoff
Martin
« Reply #8 on: January 10, 2005, 01:47:07 PM »
Geoff,
If other searching doesn't locate your headlight problem, try pulling the headlight switch apart.
Back in July 2004 I wrote a bit about repairs to light swtiches.  You'll find it here:
http://www.fefcholden.org.au/cgi-bin/yabb/YaBB.cgi?board=howto;action=di splay;num=1091145598
It's on the General technical board, page 5
Martin
Martin
Marion.  South Aust.
Ebay user id:  lewis1411
fe2ek
« Reply #9 on: January 11, 2005, 11:40:29 AM »
Turned out to be a faulty Hi Beam switch.
Cheers Geoff
