June 13, 2025, 07:06:03 PM *
Author Topic: Carby set up for Repco x flow head  (Read 3952 times)
fastjbav6
OK start her up !
« on: December 13, 2004, 12:58:18 PM »
What carby and manifold set up did the Repco grey x flow head come out with and can this head be street driven or is it for racing only?
Regards Seb
Yellow Knight
4hammers
« Reply #1 on: December 14, 2004, 08:37:35 AM »
Hi.
Usually twin Downdraught Webers. Fully streetable with the right cam.  The manifold was a Repco item, that only fitted that head. Nothing else fits. Same with the extractors.
Why?....................You got one?
Rob J
« Reply #2 on: December 14, 2004, 09:17:32 AM »
You can custom make manifolds, any decent alloy welding company should be able to help out.
I saw a 4BBL Holley manifold custom made for a Torana with extra long runners.
It won't be original Repco, but it will get you going.
fc4me
« Reply #3 on: December 14, 2004, 11:10:11 AM »
Seb if your going to run it on the street just be carefull about the oil supplie to the rocker gear as the valve guides tend to suffer from a lack of oil unless your using a few revs.
                                              Regards Mark
FE_225
« Reply #4 on: December 14, 2004, 02:13:38 PM »
Hi Seb
The crossflow kit was sold without manifolds. Manifolds and carbs were an extra, but Repco could supply them (twin 2bbl down draught Webers as Rob said) if needed.
If you want a pic, just let me know.
Tony
Burnsy
« Reply #5 on: January 13, 2005, 12:22:03 PM »
Seb, as quoted from the Wheels Holden Handyman No 1.
The Highpower head using the original carburettor and 8 to 1 compression on a standard bore block gave out 90bhp at 5500rpm.  Repco were eventually able to coax 130bhp out of the motor by adding twin choke down draft Weber carburettors, not the expensive type fitted to Ferraris and Maseratis but the type fitted to production family saloons.
Whilst on the topic, can anyone name some of the "family saloons" that were fitted with twin choke webers?
Mike
gp
« Reply #6 on: January 13, 2005, 09:33:33 PM »
I know some of the 60's Fiats came ex factory with dual throat webers.
GP
Burnsy
« Reply #7 on: December 27, 2005, 02:15:56 PM »
Just a quick update on these downdraft carbies being discussed previously.  GP is right they were fitted to early 124 Fiats and also some early GT cortinas.  They are 28/36 DCD webers and are also what was recommended by Thomas for their twin downdraft manifolds - coming soon to a Green EK  Grin
Mike
Mike
Johns
Model: something else...
« Reply #8 on: December 28, 2005, 11:22:22 AM »
Hi Fellas,
These Webers were not only fitted to Fiat 124s, but also to most of the large 60s sedans. I have a 1965 1800b (1.8ltr 6cyl) which has a 28-36 DCD 2. The 28-36 DCD 3 was fitted to 2300s, can't readily identify the differences now . They may also have been fitted to the 4 cylinder 1500s.
The code refers to the 28mm primary and 36mm secondary throats.
I have detailed drawings of these carbs, complete tune-up info and may be able to help you locate one/two if need be.
If you need some help, send me a pm.
John Grin
Johns
« Reply #9 on: December 28, 2005, 11:28:36 AM »
Re my previous post.
The DCD 2 has primary and secondary throats (as opposed to bores) of 21mm and 23mm.
The DCD 3s are 23/25mm. The DCD 3 may be the one to go for.
regards
Page created in 0.035 seconds with 20 queries.
