August 29, 2025, 10:03:02 AM *
Author Topic: Unadulterated Complete FE wiring Harness  (Read 2039 times)
slim
« on: November 24, 2004, 08:36:30 AM »
I have a complete ORIGINAL wiring Harness out of an FE Standard sedan.  It is complete with all fittings, Plugs , ETC ETC. This harness has not been cut up , And is in good condition. I want $100 for the Complete harness, Front to rear and all in betweens. Contact Slim 0401303998.
Im located at Liverpool, NSW
Blown_FC
« Reply #1 on: January 06, 2005, 05:19:43 AM »
What's the difference between FE & FC ?
I have an FC with RED 202, Electronic Distributor, Electronic Fan, and Electronic Fuel Pump, Electronic Wipers......would like to install a half decent stereo later aswell.....would this harness be up to the task ?
How good is good condition ?
CHeers
Mark
« Reply #2 on: January 06, 2005, 06:40:48 AM »
Location of front parking lamps (although strictly speaking this is forward of the junction block, and not part of the harness per se), and depending on age of FC, wiring for rear blinkers (Oct-Dec '59 have rear indicators separate from brake lights.)
Only a half-decent one? Roll Eyes
Others can answer the question better than I, but bear in mind it's still the best part of 50 years old, and sounds like it will need a few more lines run, relays and fuses added for what you're planning.  There's another concurrent thread talking about wiring kits that I'm sure you've been following too.
Page created in 0.04 seconds with 17 queries.
