May 16, 2025, 10:12:43 PM *
Author Topic: Engine help, Which way do I go !  (Read 2104 times)
Kermit
« on: October 20, 2004, 08:46:15 PM »
Hi All,
I am hoping that the forum can give me "devine guidance" on the following.
I have made up my mind to fit a HR front end into my EK, and as such realise that the outrigger must be changed. I have also become aware that the current 138 is blowing a lot of smoke out of the breather and constantly dripping oil out of the breather. So "assuming" my motor (not the original) needs work / replacement, which of the following options should i go with;
1/ Change outrigger and have my motor recond $2500
2/ Change Outrigger and Buy "Good" secondhand Grey motor, cost approx $250 to 500
3/ Leave HR outrigger in place, buy "Reconditioned 161 motor" cost $1585. I am assuming with this option that the mounts for 161 are same as for HR Front End + manifolds etc off 186 will fit on 161 + that the Grey box will fit straight up to the 161
Forum comments welcome
Rgds
Mick
« Last Edit: October 20, 2004, 08:48:31 PM by just_mick » Logged
HYSTERIA
« Reply #1 on: October 20, 2004, 09:34:42 PM »
Good luck finding a good second hand grey motor, I looked for 6 months and found nothing but freshly painted crap. In the end I recoed a second hand grey that I bought out of the trading post, budget for about $2000 for a good reco job for these motors. If originality is not high on your priority list, I would go for a red motor.
EK 215 - Who needs all that chrome
« Reply #2 on: October 20, 2004, 09:38:58 PM »
"Kermit",
If you need a good second hand grey motor I may be able to assist. Engine hasn't been wrecker reconditioned (repainted), and came out of a driving car. You would need to pick it up from my place, in outer western Sydney.
Just send me a message on Craig@ctcgroup.com.au.
« Last Edit: October 20, 2004, 09:41:04 PM by craiga » Logged
Dr_Terry
« Reply #3 on: October 21, 2004, 06:30:02 AM »
Hi Guys.
You have to change the outrigger anyway, even if you do fit a Red motor. The front of the outrigger, with it's single bolt mounting won't fit the EK.
Also if you're fitting a Red, the HR mounts have to be moved rearward approx 3 inches because the engine sits further back in the engine bay in FE-EH than it does in HD/HR.
Hope this helps.
Dr Terry.
