May 17, 2025, 08:51:59 AM *
Author Topic: Any "Electric Wiper" experts out there  (Read 4045 times)
Kermit
« on: September 15, 2004, 05:40:56 AM »
I know this subject has been covered before and i have be going over time and time again the words and diagrams from people that have done it before, but I have spent a whole day on it and "I'm stuffed iif i can work it out. I have purchased a "VS" commodore wiper moter which only turns in one direction which is to the left when siting in the car, so with this "only turn left action in mind" how do i connect two wiper arms that need to work in opposite directions, ie to make the wipers move up the windscreen they both need to pull to the center which in a one direction moter i cannot see how its possible "all help please"
Rgds
Mick
-KIWI-
« Reply #1 on: September 15, 2004, 06:22:17 AM »
try this thread:
http://www.fefcholden.org.au/cgi-bin/yabb/YaBB.cgi?board=hotup;action=display;num=1012649212;start=14
Kermit
« Reply #2 on: September 15, 2004, 06:49:36 AM »
Sorry, the info and pictures dont help as I already have the wiper motor mounted correctly in the car and have extended the shaft on the motor, it's how to make the 2 wiper arms mover in the right direction that has me stumped
rgds
Mick
-KIWI-
« Reply #3 on: September 15, 2004, 07:50:01 AM »
using a cam set up i will email you a pic of one if you like
Sarge
« Reply #4 on: September 15, 2004, 08:57:46 AM »
Mick If Kiwi cant help you, but I am sure he will be able to. I only changed the way that my wipper linkages fitted on to the motor. All my linkage set up is what the General put in the car in the first place. So get a good nights sleep and tomorrow, just take the linkage that use to fit on to the old motor and make it fit onto the new motor.
Sarge
        0421 165 351
sgo
« Reply #5 on: September 15, 2004, 09:41:03 AM »
There's a bit more info above in the  "2 speed wipers" post and should explain how to get the arms to turn as the should.
You've got my sympathy as I couldn't get my head around it either till I saw some pics. I had never seen the original electric set up either so had nothing to go on as well! :-/
Kermit
« Reply #6 on: September 15, 2004, 09:32:07 PM »
Thanks everyone for your replies i have arranged to go see a car with Electric Wipers fitted on the weekend so i should be okay then.
Thanks again
Rgds
Mick (Kermit)
Sarge
« Reply #7 on: September 16, 2004, 07:41:52 AM »
Mick
     If its any help I can take photos of mine in the FE Sedan and post here for you just give me a couple daysss mate.
let us know
Sarge
        0421 165 351
« Reply #8 on: September 16, 2004, 09:54:57 AM »
FC wiper motor oscillates, all electric motors rotate.
FC wipers oppose each other whilst EJ onwards work in parallel
EK has opposing wipers with an electric motor - its the only Holden which does this from the factory.
What u have to achieve is an oscillating motion from a rotating motor.
Once you see how an EK motor works u can see what you need to do.
All you need is an EK motor to fit electric wipers to an FC
If u have an EK motor - I can convert it to 2 speed 4u
