August 02, 2025, 11:00:20 PM *
Author Topic: under floor crossmember  (Read 3184 times)
« on: September 02, 2004, 07:40:46 AM »
I need the piece of crossmember under the front floor between the inner subframe legs.
Its the piece that you would normally cut out if you were putting a 4 speed in an FC
You know the piece that the handbrake bracket bolts onto.
Anyone wrecking a car with this piece in rust free order.
All I need is basically between the 2 inner subframe legs
Any help or leeds would be appreciated.
I am in Vic but I wouldn't expect the postage to be more than about $20 from other states.
Regards   Ken
davids_ute
« Reply #1 on: September 02, 2004, 10:58:50 AM »
ken i have sent 2 emails(hope u got them) think i have got wat u want and i am in geelong not to far away u can call me on 03 52784474        regards david
« Reply #2 on: October 22, 2004, 10:15:40 AM »
Still looking for this piece of floor, surely there must be someone out there who has a wreck with a half decent bit of floor in it ?
It wouldn't cost much to post from interstate I believe - can anyone help?
« Reply #3 on: October 22, 2004, 10:40:09 AM »
Do you have a picture of the area that you need?
« Reply #4 on: October 31, 2004, 09:23:20 AM »
No I dont have a digital camera unfortunately
Trevor_B
Melbourne VIC
« Reply #5 on: November 01, 2004, 12:25:37 AM »
Hi Ken,
You might try Centre Road Wreckers  - 1602 Centre Rd Springvale 3171  (03) 9547 7377
When I was there a couple of months ago they had a reasonable FC shell, although I didn't get under it to check for rust. Perhaps you could give them a call.
Alternatively you could try this guy in Castlemaine:
Bought some parts on Saturday from an old bloke in Castlemaine who had an FC Wagon and a Panel Van he is wrecking. Most good bits already gone (isn't that always the case?) although I got some good parts, like a HR disc brake front end ex the FC Wagon (needs some TLC & new rotor/calipers), headlight trim, couple of original washer jets and a grill (complete with a badge).
This guys still does have some useable bits like front sub chassis, complete rear axle assy, steering box, Front right guard, rear tailgate & window for both (seemed in reasonable condition given that it was raining at the time of viewing). Also had other parts lying around along with a couple of EH's. Price was good for the bits I bought.
His name is Ron - Ph No 5472 3839
Trevor_B
earlyholdenfan
« Reply #6 on: November 01, 2004, 09:04:57 AM »
Ken, if you still have no luck, I would be msot willing to bring the diigi camera over and capture the offending part on film for you to post!
Matt
slim
« Reply #7 on: November 02, 2004, 08:27:39 PM »
Ken , I have just picked up an FE sedan , Im wrecking. If you can let me know if you have located what you need, And perhaps put a small diagram of area needed , I can Help . Cheers SLIM
Im located at Liverpool, NSW
« Reply #8 on: November 07, 2004, 08:51:02 AM »
Slim, thanks for that - I have a promise of one coming in 2 weeks but I will let you know if it falls through
Page created in 0.054 seconds with 18 queries.
