August 30, 2025, 07:15:54 AM *
Author Topic: Hi-Beam light  (Read 4585 times)
Phantom
« on: September 01, 2004, 08:55:41 AM »
This might be a dumb question, but is there a high beam light in the speedo ?
                               Cheers Rusty
Bogans rule
Paul-FcWag
Artist formerly known as Thumper
« Reply #1 on: September 01, 2004, 09:00:26 AM »
Sure is Phantom
it is blue, or rather the lens is blue and from memory i think it is located at the bottom centre of the speedo  Huh
« Reply #2 on: September 01, 2004, 09:09:22 AM »
Hi Phantom and Thumper,
My FCs have a red high beam indicator light at the top of the speedo. Wink Grin Grin Grin Grin
ACE Cool
« Last Edit: September 01, 2004, 09:10:45 AM by ACE » Logged
Phantom
« Reply #3 on: September 01, 2004, 09:12:32 AM »
Thanks thumper, i had a globe holder hanging around under the dash and no high beam light so i sorta  figured out that is what it mighta been ,will have to wedge myself under the seat somehow and have a look, thanks for your help.
                                  Cheers Rusty
Bogans rule
Sarge
« Reply #4 on: September 01, 2004, 10:24:36 AM »
Rusty
        Top, Centre. Easy way is to take the two retaining screws from the instrument cluster out (found at the bottom one is near the handbrake handle), pull cluster up and forward. You will see at the top of the speedo head where the light fits into. Oh don't forget to undo your speedo cable as well.
        Or you can just wedge yourself under the dash and have a feel around for the top of the speedo for a small hole in the centre and push your spare light fitting into that.
Sarge
        0421 165 351
Phantom
« Reply #5 on: September 02, 2004, 03:14:47 AM »
Cheers Sarge, thanks mate will have a go at squeezing under the dash first i think(if my pot belly and age will allow for that type of gymnastics that is)
                                             Cheers Rusty
Bogans rule
Phantom
« Reply #6 on: September 02, 2004, 05:11:35 AM »
Sarge , managed to get under the dash and found an empty hole but is thre globe size too big? what is the correct size globe , any one got a pic?
                                               Cheers rusty
Bogans rule
« Reply #7 on: September 02, 2004, 05:31:23 AM »
Looks alright to me.  The hole for the hi-beam indicator light is a standard half-inch (roughly) hole, same as the ones for the speedo lighting on either side of the speedo cable.  According to the wiring diagram here, it should be a light-green wire, too.
Phantom
« Reply #8 on: September 02, 2004, 05:46:07 AM »
Hmmmmm must have it in the wrong hole, the globe seems to be hitting something
                                        Rusty
Bogans rule
« Reply #9 on: September 02, 2004, 07:49:20 AM »
Actually the high beam globe is smaller in diameter than all the others.  It is 1 candle power rather than 2 candle power of all the others.  (refer p25 of the owners booklet) But the bigger globe will fit in the hole.
I think it is lower power because it would burn the cardboard tube that it sits in.
Possibly yours is fouling because the cardboard tube is out of place
Page created in 0.034 seconds with 17 queries.
