May 16, 2025, 04:25:31 PM *
Author Topic: Help with twin Strombergs  (Read 2147 times)
Kermit
« on: July 22, 2004, 11:46:13 PM »
I am soon to fit twin Strombergs to my EK, can anyone tell me if i have to change jets or any other items or do i simply bolt the 2 carby's on and then tune it.
Any advice is much appreciated
Rgds
Mick
FCwagon
« Reply #1 on: July 23, 2004, 02:19:41 AM »
Hi Mick,
If it's a stock grey motor then just chuck two stock carbies on and reduce the main jet sizes by one. The power jets can stay std. If it's a hottie, then you'll probably need to experiment with the mains and power jet sizes.
If it's a red motor, the best set-up is that for an X2 which is 2 x 149 carbies. I can get you the details if it is a red but even that depends on what size red.
Hope this helps a bit.
Leigh
Red & white is alright
Kermit
« Reply #2 on: July 23, 2004, 03:00:41 AM »
Thanks Leigh,
It is a Grey motor with Extractors and twin Stroms only
Rgds
Mick
nicko
« Reply #3 on: July 23, 2004, 03:56:15 AM »
it all depends as they might already be set up right ,i would pull them both down for a start and clean ,check float levels and pull jets out and look if they are matching numbers for a good starting point
Kermit
« Reply #4 on: July 23, 2004, 06:22:14 AM »
Thanks Nicko, I appreciate the help
Rgds
Mick
