May 16, 2025, 03:33:07 PM *
Author Topic: Torana Suspended FC  (Read 1837 times)
Spinner
« on: July 01, 2004, 11:35:15 AM »
Probably been talked about before...
Any ideas or experience in fitting a UC Torana front crossmember & suspension to an FE/FC?  I thought it might be a good idea because you get RTS (Mk II) and Rack & Pinion Steering.
Fitting the trailing arm rear and might be a tad difficult though.
Spinner
« Reply #1 on: July 01, 2004, 09:09:57 PM »
Ive seen a Torana front under Ahmet the Mad Turks HD ute.
the bolt holes dont align properly with the subframe, and i reckon it looks bodgey (big plates and bolts), Ahmet reckons its fine, and the ute goes hard so...Huh
I cant shed any light on the angle the x member sits and subsequent effects on castor angles etc.
the trailing arm rear wouldn't be too hard to apapt, but I would scratch build a 4 bar for less stuffing about.
« Reply #2 on: July 04, 2004, 02:04:46 AM »
i have just seen some photo's of EH sedan with Torana LH front end and they cut crossmember in half and widened it by 2 inches by welding in steel plates
