September 09, 2025, 07:48:26 PM *
Author Topic: EH COLUMN  (Read 3598 times)
RUBBLE
FC WAGONS ARE COOOOOOL
« on: June 25, 2004, 04:28:40 AM »
HEY GUYS Wink
ANYBODY KNOW IF A STEERING COLUMN AND BOX OUT OF A EH WILL BOLT UP TO MY FC,IF SO IS THERE MUCH STUFFING AROUND TO MAKE IT FIT?
WHAT IS THE BEST TRANS TUNNEL TO WELD IN TO TAKE A MANUAL BOX(4 SPEED)?
CHEERS RUBBLE Cool
« Reply #1 on: June 25, 2004, 05:40:31 AM »
No need to shout Wink
EH Column is a bolt-up fit I'm pretty sure.  One of my earlier FCs had one.  It might require EH pitman and idler, not sure about that.
EK auto tunnel is the best and neatest if you want a whole new one, but they're getting awfully hard to come by these days.  It's actually a lot easier to cut an H-shaped slit in your existing floor and create an enlarged tunnel than completely replace the floor and tunnel.  Quite a few people have documented how they did this on the forum at various times.
Either way will probably require custom floor covering (carpet).
Hope that helps,
Fast_Eddie
« Reply #2 on: June 25, 2004, 06:54:40 AM »
Castlemaine Rod shop sell a formed transmission hump that can be welded in. It is the same shape as an EK auto floor hump.
I assume that by using it, you could order floor coverings that suit an EK auto, which,  in all other respects is the same floor pan as an FC.
RUBBLE
« Reply #3 on: July 04, 2004, 12:54:24 AM »
THANKS FOR THE REPLYS GUYS. Wink
I WILL BOLT UP THE COLUMN AND SEE HOW I GO
CHEERS RUBBLE Cool
Phantom
« Reply #4 on: July 04, 2004, 08:07:02 AM »
Hey Rubble do you know that if you type in capitals it is deemed as YELLING?
                                      Cheers Rusty
Bogans rule
RUBBLE
« Reply #5 on: July 04, 2004, 09:57:28 AM »
no but i do now Huh
surferboy
10,000 POINTS !
« Reply #6 on: July 04, 2004, 11:11:57 PM »
but those of us who are deaf can read it better
cruisin's great with a 58
« Reply #7 on: July 05, 2004, 08:56:58 AM »
Hey Rubble
I have fitted an HR column to the FE with no probs, so far. I have not re-fitted the plates that go on the firewall though as they have been "mis-placed" somewhere between here and the powder-coaters.
Anyway, the HR column only had two bolts (instead of three) to the sub-frame and I had to stretch one about 5mm.
