July 13, 2025, 06:22:45 PM *
Author Topic: FEE from Trundle  (Read 7887 times)
leon
My FC Business Sedan
« on: June 17, 2004, 09:16:46 PM »
 Wink G Day fellows.
Here is a photo of the gaurds after I striped the paint off and theres no bad rust only light; It took 3 hours each gaurd.
I'll keep you posted. Wink
Regards. Leon
« Reply #1 on: June 18, 2004, 03:16:47 AM »
Geez Leon, this stuff you are posting is borderline pornography. You'd better give a warning if you post pics of any more beaut stuff like that Smiley
« Last Edit: June 18, 2004, 03:17:04 AM by stinky » Logged
« Reply #2 on: June 18, 2004, 09:40:57 AM »
WOW. Those are some of the cleanest guards I have ever seen. If the rest of the car is like those, half your restoration is done.
leon
« Reply #3 on: June 19, 2004, 07:04:34 AM »
 :)Thanks Alex.
Its all not that easy. Its time effort and keeping at it and if all goes well I should have the guards and the front end etch primed' primer undercoat'  guide coated and if  the weather is fine  i'll hit it with the colour coat(Levant green).
Reagrds. Leon Wink
Burnsy
« Reply #4 on: June 19, 2004, 11:42:28 AM »
Nice job Leon, what did you use to strip those guards with?
Mike
« Reply #5 on: June 19, 2004, 12:05:28 PM »
Yeah, lookin good Leon, nice work, go the green!!
Gary
Martin
« Reply #6 on: June 19, 2004, 12:16:03 PM »
Nice and clean, Leon.  I too would like to know what you used to strip the guards.  I'm into collecting this sort of info at present, before I tackle mine.
Martin
Martin
Marion.  South Aust.
Ebay user id:  lewis1411
leon
« Reply #7 on: June 19, 2004, 08:50:01 PM »
 :)G Day fellows.
RE the paint stripper. I used steptone automotive paint stripper from supercheap.
I apply 2 coats' one takes off the first and some of  undercoat and the second coat takes off the rest then I use a course grade steelwool with a bucket of water (not a hose) and rub hard.
When applying the stripper do it in the shade not in the sun as it dries the stripper very fast and makes it harder to remove.
I hope this helps. Wink
Regards leon
Martin
« Reply #8 on: June 20, 2004, 02:24:12 PM »
Thanks for the info, Leon.
There's quite a discussion about sandblasting and paint strippers in the Restoration Help board (under the subject line "sandblasting Huh") that suggests paint stripper doesn't work so well on nitro-celluose paint (as originally applied to FEs and FCs)
Was your paint work the original?  Your method seems to be quick and efficient.
Regards,
Martin
Martin
Marion.  South Aust.
« Reply #9 on: June 21, 2004, 12:48:36 AM »
I use the same method as Leon, only I use thinners instead of water, I've found that the red primer / undercoat is much harder to remove than the topcoat.
Hey Leon, are you going for a fleet of green FE's???
Gary
leon
« Reply #10 on: June 22, 2004, 07:10:08 AM »
 :)G Day fellows.
I use the paint stripper because I don't have a sand blasting machine I've seen panels that have been sand blasted and some have been put out of shape.
I know I have full control when I do it myself my way.
It may be slow but the job gets done and I know it's done right. Besides I enjoy doing it.
I had no problem striping the old paint off.
As far as I know it's all original paint work if it wasn't   I wouldn't  have the car.
Answer to your question Garry, When FEE NO.2 is finished it should look like your FE.
Here is an update photo so far.
Regards Leon. Wink
leon
« Reply #11 on: June 22, 2004, 07:13:51 AM »
 :)Here's another photo
Regards. Leon  Wink
ChrisB
"Shiny Bits"
« Reply #12 on: June 22, 2004, 08:27:12 AM »
Its looking real nice Leon
ChrisB  Cool
Fast_Eddie
« Reply #13 on: June 22, 2004, 08:34:47 AM »
Nice work Leon.
Are you using 2 Pack or acrylic?
Edward
Emu
Emu's Ashes pic - Aussies 5-0
« Reply #14 on: June 22, 2004, 09:21:02 AM »
Sweeeeet!!!
craiga
« Reply #15 on: June 22, 2004, 09:28:00 AM »
Looks great Leon.
It will make a really good partner for the Standard FE.
Craig.
« Reply #16 on: June 22, 2004, 10:03:22 AM »
Hey Leon.
You don't mess about. I guess you gotta get the paint on before it gets too cold to do so.
Nice work thus far.
gp
act-club
« Reply #17 on: June 22, 2004, 09:00:11 PM »
Hey Leon,
looks great. That's what my FC came up like when I used paint stripper. I still think that gives the best results (as per the earlier post in the restoration section). I think the photos show the excellent results you get with paint stripper.
Yes, I agree, you need to have 2 goes to get the original paint off, that red oxide undercoat is very stubborn.
Graham.
graham_fuller
« Reply #18 on: June 23, 2004, 01:00:35 AM »
Leon,
Looks great.When will we do mine?Needs to be a different colour though.When is the completion date mate.
cheers,
Graham
leon
« Reply #19 on: June 23, 2004, 03:39:00 AM »
 :)G Day fellows.
I'm using acrylic as I fine it to be realy easy although i've never used anything else.
2 pack seems to be to modern for the old girls although I think its a good modern paint with good out standing properties.
Answer to Graham's question. I realy don't know, no set time just getting stuck into it.
Here is a photo of FEEno.2 when I first got it.
PS. Thanks you all for all your intrest.
Regards. Leon Wink
Page created in 0.042 seconds with 21 queries.
