May 19, 2025, 02:26:11 PM *
Author Topic: tripple carbs trick  (Read 4397 times)
nicko
« on: June 16, 2004, 04:31:33 AM »
i have just recieved a set of tripple strombergs from Slim(thanks Slim)and was wondering if i can just use the middle carby or will the other two ports run lean,its on a single manifold with 3 flanges spaced evenly?
crossing my fingers that i can as they would look fantastic under the hood until i find warm cam and time to rebuild engine.
reguards Nicko
Jockster
« Reply #1 on: June 16, 2004, 04:54:20 AM »
Nicko
You should be able to run one centre operating carby and two dummy carbs each end, but you will need to fit blanking gaskets under the end carbs to avoid any vacuum drop through the throttle butterflies and shafts. With the two carbs blanked it should operate  like a normal manifold.
Jock
slim
« Reply #2 on: June 16, 2004, 05:39:22 AM »
Glad they got there OK. Cheers SLIM
Im located at Liverpool, NSW
nicko
« Reply #3 on: June 16, 2004, 08:25:03 AM »
Slim,you must have bolted to the post office  as they arrived this morning,lot of work to do now but they are very nice sets bud.
also thanks for the info Jockster, Wink
reguards Nicko
« Last Edit: June 16, 2004, 08:26:13 AM by nicko » Logged
rip_ute
59 UTE and 59 S/W
« Reply #4 on: March 11, 2006, 11:08:19 PM »
Nicko. How did this idea go, did it work or not?
Jockster or any one else who has done this or knows of it been done. How good did it run and was there any promblems?
Thanks. Peter.
trevwood
« Reply #5 on: March 11, 2006, 11:43:31 PM »
G'day Nicko I know of 2 EK wagons that run tripple carbs, the way they are set up is to use the center carb for cruzin and the two outer ones kick in when hard exceleration is needed eg; uphills or towing. It is set up using a progresive linkage and fuel economy is not affected when cruzin round town. My question is why put tripple carbs on if your not going to use them?
      Something to think about anyway! Trev.
TorqueFC
Modified?
« Reply #6 on: March 12, 2006, 12:03:33 AM »
thats the setup on the wagon (thats if you are who i think you are  Roll Eyes )
if you look closely you an see the progressive linkage, i think your brother Sam said the other 2 carbs kicked in around 4500 rpm??
« Last Edit: March 12, 2006, 12:07:29 AM by torquefc » Logged
nicko
« Reply #7 on: March 12, 2006, 12:40:02 AM »
thats an awsome looking set up Torque
your car has come up very nice.must be a blast to drive around in a hot grey,
also yes the blanked off carbs work well with only the centre carb working, but would have been painfull in mild motor,
trevwood
« Reply #8 on: March 13, 2006, 05:49:54 AM »
Yep thats the car I was talkin about, great picture tourqueFC.
