August 30, 2025, 08:23:49 AM *
Author Topic: Gemini Brake Booster  (Read 5338 times)
Burnsy
« on: June 06, 2004, 08:22:26 AM »
Can anyone fill me in on Gemini brake boosters, I am looking at one for my EK but anyones infor from their FE-FC conversion would be a great help.  Questions that spring to mind are:
Are the gemini units dual circuit?
If so, what size rear slaves do I need?
Can I bolt a gemini booster and master straight up for Torri disks or do I need a different master?
Mike
Mike
Burnsy
« Reply #1 on: June 06, 2004, 08:33:49 AM »
Just another thought, does anybody know what size EK rear slaves are and are they the same as the front?  I seem to recall reading somewhere that the FB and EK cylinders where a different size to FE and FC's?
Mike
« Reply #2 on: June 06, 2004, 09:53:33 AM »
Hi Burnsy,
I've seen this conversion done to a EH Holden.
He used a Gemini Booster and Dual circuit master cylinder connected to Torana front discs with 9/16 rear wheel cylinders.
FE-EK front wheel cylinders are 1 3/16''
FE-EK rear wheel cylinders are  1  1/16''
FE-FC rear brake cylinders are not interchangeable with FB-EK as they have a different brake pipe size.
Hope this helps,
Regards ACE Cool
Digger
Classic not Plastic
« Reply #3 on: June 07, 2004, 09:07:04 AM »
Burnsy,
When using the Gemini booster it is best to run a F##d XB master cylinder I think they are a 1" bore.
Hope it helps,
Steve.
Sarge
« Reply #4 on: June 07, 2004, 10:05:07 AM »
Burnsy,
          I am running Commodore disc brakes both front and rear. I am using TE Gemini booster and master cylinder. Just made my own brake line's to suit. Hope this is of some help to you.
Sarge
        0421 165 351
Burnsy
« Reply #5 on: June 08, 2004, 09:18:20 AM »
Can anyone tell me the diameter of the gemini booster, my EK is Auto and it doesnt have much room between the master cylinder and the bonnet hinge - only 65mm to the centre of the cylinder to be precise :-/, may have to go back to the VH40 option.
Why is it better to use a one inch Fxxx master cylinder if Sarge is able to run front and rear disks off a gemini master, why change it?  After all who likes to contaminate their Holden if they don't have too!!!
« Last Edit: June 08, 2004, 09:19:57 AM by Burnsy » Logged
Mike
Effie C
Still Lost & Confused
« Reply #6 on: June 08, 2004, 09:36:06 AM »
V6 conversions use the crummydore booster in FE FC'sand the gemini booster in FB EK's. Check out their site as it contains some info.
John M
http://www.v6conversions.com.au/
