August 30, 2025, 01:10:27 PM *
Author Topic: torana diff  (Read 3681 times)
nicko
« on: June 02, 2004, 08:39:33 AM »
HI can anyone tell me if an LH Torana diff is longer ,shorter or the same length as an FC diff?
fcvan
« Reply #1 on: June 03, 2004, 12:12:08 PM »
Hey Nicko,
 I don't know the exact diff length but I do have the wheel track measurements.  FC is 1410mm and LH is 1430mm.  I don't know what width wheels/ offsets the LH runs but you would think the diff lengths would be fairly close. Hope this helps a little but I'm sure everyone else will add some more exact info.
miikael
« Reply #2 on: June 04, 2004, 07:48:44 AM »
I think the LH diff is the same as FC, if you want a narrower diff then the LC or LJ diff is the one to get as this is about 2 inches shorter
nicko
« Reply #3 on: June 04, 2004, 11:31:18 AM »
thanks ,i will get rid of it and chase up an LJ as i want a couple of inches more clearance on ute for the Western deep dish kidney's
Burnsy
« Reply #4 on: June 11, 2004, 07:50:34 AM »
I have just found a LH diff for my car (EK) can anyone tell me what is involved in putting it in, is it a simple bolt up using the torana plates and u bolts or do I need to weld mounts on or something?
Mike
Mike
ACE
DOH!!!!!!!!!!!! !!!!
« Reply #5 on: June 11, 2004, 08:36:34 AM »
Hi Burnsy,
You'll have to cut off all the Torana coil spring  mounts and weld mounting plates on to accept the EK leaf springs. Wink
Hope this Helps,
Regards ACE Cool
Burnsy
« Reply #6 on: June 11, 2004, 10:31:45 AM »
Can anyone give me any advice on setting up the handbrake using the Torana diff and drums.
Mike
Page created in 0.033 seconds with 16 queries.
