Blown_FC
« on: May 24, 2004, 10:16:13 PM » |
I'm at that stage of trial fitting everything into my FC Sedan and notice that the radiator that was in the car when I bought it, is not original. It's a lot wider, and therefore the previous owner has cut away part of the front of the subframe to allow airflow to it.
Problem is, that I've fitted a new subframe, that hasn't been cut up, and I'd rather keep it that way if possible.
So my question is......."Is a standard sized FC radiator sufficient enough for a XU1 replica 202" ?
I'd probably get a beefed up you beaut triple flow radiator, but FC sized, or is it best to cut out the front parts of the subframe and fit a bigger radiator ?
The motor is a red 202, YT head, Triple strommies, XU1 cam, Extractors bla bla bla !
It is also running a trimatic and yes, I have a seperate oil cooler !
Any ideas, tip and pics would be appreciated !
Mark
craiga
« Reply #1 on: May 24, 2004, 10:35:03 PM » |
Mark,
I don't reckon the standard size radiator will even come close. A couple of us use the standard one with red motors but these aren't worked, and they definately can have a tendency to get a little hot in summer.
You can get an aftermarket triple core from Aussie Desert Cooler radiators, which may cope, but you don't want to go to all this effort and have a car you can only drive on cool days with no traffic. I reckon you should go with the bigger radiator.
Craig.
Blown_FC
« Reply #3 on: May 24, 2004, 11:47:16 PM » |
Thanks for that guys...
I've called Aussie Desert Coolers in the mean time, and they quote a Triple flow ( 3 core ) replacement FC unit for $370. Norm says it will handle the red 202...but then again, he's selling them, so he would say that !
Has anyone ever fitted an Aussie desert cooler ?
Mark
nicko
« Reply #4 on: May 25, 2004, 12:59:56 AM » |
i ran an aussie dessert cooler in an f%#d XY it was fitted to standard xy radiator top and bottom tank and was 3 core to try and tame my 302boss (windsor bottom end with clevo heads) and it did a great job.and $370 quoted sounds like cheap insurance for your engine.
« Last Edit: May 25, 2004, 01:01:29 AM by nicko »
Online
« Reply #5 on: May 25, 2004, 09:33:52 AM » |
Hey Mark Norm at Aussie Desert Cooler has a very good reputation. I think if he says it will do the job, then it will. Personally I would still go for a bigger HR radiator with some extra cooling built in to be sure it never boils. Regards Alex
« Last Edit: May 25, 2004, 09:35:53 AM by custom_fc »
fjalldway
Offline
« Reply #6 on: May 25, 2004, 11:29:18 AM » |
how much does Aussie Desert Coolers charge for their radiators in Aluminium??
how much better would alloy be?
Blown_FC
« Reply #7 on: May 25, 2004, 10:04:47 PM » |
DECISION MADE !
Thanks everyone for all your tips...but I've made a call and gone with a Aussie Desert Cooler.
I spoke to Norm this morning to clarify a few things. He said the $370 radiator is their PERFORMANCE SINGLE PASS unit. But I want better cooling, so I asked about his TRIPLE FLOW units..( pays to read streetmachine ), anyhow, he confirmed that the triple flows are at least 15% better than standard Performance Single Pass units. He also said, that Copper, Brass or Alloy make no difference is cooling, just more a cosmetic, personal choice really.
So the Triple flows are $440....but said he'd do me one for $400 straight !
I double checked about the efficiency witha hot 6 motor, and he personally guaranteed it.
He said, that they don't deal in bullshit, and he will guarantee it will be more than enough radiator for the job.
That's enough assurance for me !
So it will be FC size and should bolt straight in with no cutting or messing around !
But to be on the safe side, I should avoid burnouts in the middle of summer....but hey....it's not a drag car !
Thanks again for all your thoughts
Mark
