August 30, 2025, 06:49:30 AM *
Author Topic: proportionong valve  (Read 2299 times)
Phantom
« on: May 11, 2004, 07:29:08 PM »
G'day all,
               Does anyone out there know if a HQ proportioning valve will work with my HR disc front end and a FC drum rear end , will it help the dreaded rear end lock up?                      Cheers Rusty
Bogans rule
Digger
Classic not Plastic
« Reply #1 on: May 11, 2004, 11:17:34 PM »
Hi there Rusty,
The HQ proportioning valve (Limiting Valve ) will work fine.
You can also change the rear wheel cylinder size to a larger bore and will have the same efect.
PBR have a 9/16ths wheel cylinder that will bolt in and you wont need the proportioning valve.
One thing Rusty have you a HR rear drum set up for disk or the standard HR set up and are you boosting the hole brake set up or just the front disks.
Steve.
« Last Edit: May 11, 2004, 11:31:16 PM by digger » Logged
« Reply #2 on: May 12, 2004, 01:59:17 AM »
Phantom,
Have a look at page 2 in this section with the heading
"Rear Brake Cylinders"!!!!!!!!!!
This should help answer your questions. Wink
Regards ACE Cool
