July 15, 2025, 06:17:10 PM *
Author Topic: radiater size  (Read 1452 times)
andyk
« on: June 08, 2001, 12:00:00 PM »
does anyone know of a 3 or 4 core radiater, size around 400mm x 6 to 700mm wide, that will mount in front of the radiater wall on the FC. Hopefully with the water inlets on the correct sides.  thanks
Richard
« Reply #1 on: June 13, 2001, 12:00:00 PM »
I've seen this done using a Ford Laser radiator.  I couldn't tell you which exact model though.  It fitted really neatly under the brace that the radiator cowl bolts to.
Hope that helps
Page created in 0.029 seconds with 14 queries.
