July 26, 2025, 06:17:17 PM *
Author Topic: Dash Destruction  (Read 3230 times)
Paul-FcWag
Artist formerly known as Thumper
« on: May 05, 2004, 03:15:23 AM »
Catchy subject title hey!!! Grin
Ive just got a new plastic guard that goes around the guages on the dash- i know this housing has a name but cant think of it- im sure u all know what i mean.
anyway i was about to take the old 1 off and put the new 1 on when i realised the screws in the old 1 are from behind the dash and then i saw what i had to take off to get in there.
Aside from this the dash needs nothing doing to it- so im pretty much pulling it apart just to get this on.
Is there an easier way of doing it that im not seeing?
Im not sure that there is, i just thought id ask for a few words of all the wise on here. Wink
ill hope to have pic on here soon- shes nearlly ready to be revealed- in all her ugly glory Grin Grin
any help will be appreciated!
thanks all
FATBOY
« Reply #1 on: May 05, 2004, 04:18:38 AM »
if any body is after one of these surrounds i have one for sale fatboy
fatboy
0414712441
« Reply #2 on: May 05, 2004, 04:27:51 AM »
You'll need to pull the dash out. Under the dash there are two flat headed screws - one either side of the steering column. Remove these, then put your hand up behind and feel for the speedo cable. Undo the knurled retainer and slip the cable out. Put a towel or good thick rag on your steering column, lift off the dash (it lifts UP then OUT) and lay it on the towel. Your movement will be limited by the headlight switch wiring (and maybe the choke cable) but it should be enough to get the screws out and replace the dash fascia. If not, undo the choke at the carby and free the cable assembly, this should give you plenty more movement.
Good luck, can't wait to see the photos.
« Reply #3 on: May 05, 2004, 04:28:42 AM »
Fatboy - howmuchdoyouwant?
I need one for the wagon.
mickusmickus
Brisbane, Queensland
« Reply #4 on: May 05, 2004, 06:37:45 AM »
This realy isnt that hard to do you shouldnt need to remove anything bar the dash panel and speedo cable but I do agree make sure you put a THICK rag on the column cause my dash panel fell victum to thin rag abuse and i had to repaint it.
MICK
FE_STD_WAGON
« Reply #5 on: May 05, 2004, 08:05:17 AM »
thumper the most important thing to do first is to dis connect the battery  as there are live wires on the ignition and light switches I would hate to hear the old girl is developing a smoking habit  Wink
regards Mick
Paul-FcWag
« Reply #6 on: May 05, 2004, 08:36:16 AM »
Thanks for all the help guys
im sooo tempted to glue the thing on hey Grin
fear not- i wont do that!
all the help is appreciated!
thanks again
« Reply #7 on: May 05, 2004, 10:27:04 AM »
Before you pull the dash panel, or put it back, make sure all the dash illumination globes are working, easier to replace while it's out.
Cheers, Gary
